4.6cc nitro engine..
Old 06-23-2009 | 10:38 PM
chuakevs's Avatar
Questions?? 4.6cc nitro engine..
Guys, i have a question..
can i put a 4.6cc nitro engine on my HPI nitro 1/8scale on-road??..
cause it has a 3.5cc nitro engine now and im thinking that if the 4.6cc will fit??.
can it really fit??..
chuakevs is offline
Old 06-23-2009 | 11:14 PM
Roelof's Avatar
Bigger isn't faster......
The 4.6cc has the same size housing and mounting so it must fit.
Roelof is offline
Old 06-23-2009 | 11:32 PM
chuakevs's Avatar
so 3.5cc is much better than putting 4.6cc??..
chuakevs is offline
Old 06-24-2009 | 12:48 AM
Roelof's Avatar
The .28 engines are made for monstertrucks. A lot of torque but no top rpm. If you can find optional gears you can get something out of it but an 1/8 onroad racer its gears is based on high rpm engines.
Roelof is offline
Old 06-24-2009 | 01:24 AM
M7H's Avatar
M7H
3.5cc from Force.. No.
3.5cc from Novarossi/Picco/Sirio... Yes....
M7H is offline
Old 06-24-2009 | 04:14 AM
chuakevs's Avatar
oh now i get it..you dont need that much big engine for speed..thx a lot!!
chuakevs is offline
Old 06-24-2009 | 04:15 AM
chuakevs's Avatar
its a 3.5cc engine from HPI..all original
chuakevs is offline
Old 06-24-2009 | 04:18 AM
Roelof's Avatar
Is it this one?:
http://www.hpiracing.com/optionparts/stat-21rsc.htm
That is a Novarossi based engine and you can fit a new P/S set from a RX21 or 321
Roelof is offline
Old 06-24-2009 | 04:38 AM
chuakevs's Avatar
it look like that..but it got a bigger block..a violet one
and i just loved it..
and another question is 3.5cc and 4.6cc the same size but different in weight?..cause in the web the 3.5cc engine got only specifications on it..
chuakevs is offline
Old 06-24-2009 | 04:45 AM
Roelof's Avatar
As I mentioned before
Roelof is offline
Old 06-24-2009 | 06:16 AM
chuakevs's Avatar
ok thanks alot..
chuakevs is offline
Old 10-19-2009 | 04:31 PM
but can i put it on a NITRO TC3?
jonathan13 is offline
Old 10-19-2009 | 04:50 PM
Roelof's Avatar
It is no direct fit, a TC3 needs a smallblock engine but if you are handy you can fit an 3.5cc into a TC3
Roelof is offline
