Old 01-15-2004, 06:53 AM   #106
Chewdogg's Avatar
anybody know where i can purchase a 360 degree protractor to use modding timing
I got mine from Office Depot for 6 bucks.
Chewdogg is offline   Reply With Quote
Old 01-15-2004, 07:04 AM   #107
Chewdogg's Avatar
Hey guys I have seen pics of modded sleeves with bigger tapers on the bottom. What are the benefits of doing this?
Old 01-15-2004, 08:52 AM   #108
EdwardN's Avatar
Default Re: mods
thks
I got mine from Home depot, it costs about $5 including tax.
I love that one, it has two x180 degree graduation, no need to calculate ( getting lasy ). It is made out of lexan or similar clear plastic-very right tool for us.
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 01-15-2004, 08:56 AM   #109
EdwardN's Avatar
It is removing extra friction from the bottom. It is realy doesn't need to have any sealing on the bottom, so we made realy big tapper there. But it has limit, if it is too big, the piston will go out of straight line and will hit exhaust window's top line. So everything is reasonble limit. Can tell you, that one is one of the realy big secret of design, too many things are involve in this issue and a lot tries were done to find right tapering.
Old 01-15-2004, 09:12 AM   #110
EdwardN's Avatar
Default Engine modding secrets.
To add some info on engine modding secrets, can tell you, I don't have a lot of secrets from anybody, more then that on the beginnignof my present here in forum I offer my help for everyone here. More then that I was already on the process to build my motor and in the mean time offer to very respectible moddifier to supply him with my parts at very discounted price for his needs ( but i even didn't get respond). I know all my parts can be mesured and try to copy, materials can be checked for chemical constraction etc, but still don't see any secrets in it and ready to share with everyone. I do have some technological secrets, but it has nothing to do with modding. I can't release technology of piston material manufacturing, but I can supply anybody who needs with ready pistons ( by specs) or blank pistons, ready to be crinding to fit.
But unfortunately nobody needs my help in manufacturing, that is realy fine with me. Beside these couple secrets I can release any possible info on my work with engines and I am doing it so far and happy if somebody will use my expirience and knowolodge.
Old 01-15-2004, 09:17 AM   #111
EdwardN's Avatar
Induction open 30 ABDC
Induction close 65 ATDC
Hmmm.......the crank opens straight but closes in a U shape. The exhaust also closes in a U. I'll straighten them out this weekend.
It must close straight, try to fix it.
The numbers are realy good, try to save them.
On exhaust, all Novas based engines ( not only them) have arc on the top line. It is some their theory, but I use staright line theory. Don't overcut that line, too much of exhaust will cut your torq on bottom end ( dwell time will be too short).
have fun and if you have more questions, please ask
Old 01-15-2004, 02:39 PM   #112
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default NEEDLE
Efdward:
I did all the mods you suggested, I think I may have goten the taper wrong on the low speed needle. The engine loads up even with the low speed needle turned all the way in ,the mid range is set to the middle of the carb opening. When I replaced the needle with a stock one everything was perfect, this engine has throttle responce out the WAZOO!I guess I will have to try to make another needle to see if I can get it right.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 01-15-2004, 03:03 PM   #113
EdwardN's Avatar
Default Re: NEEDLE
Originally posted by Slotmachine
Efdward:
Hey Paul. Seems for me like needle isn't sharp enough-too lean on the bottom. Try to sharp it more, but don't touch the lenght please.
Old 01-18-2004, 05:06 PM   #114
ziggy12345's Avatar
Anybody got any pics of a modded crank? I know some people \Dremmel the end scoop but how?
Cheers
ziggy12345 is offline   Reply With Quote
Old 01-21-2004, 08:23 AM   #115
Chewdogg's Avatar
Hey guys what are some of the ROAR legal mods you can do to an engine?
Old 01-21-2004, 09:14 AM   #116
Grinder's Avatar
Default pictures
My website has pictures of some modified engines.
http://murnanmodified.5u.com/
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 01-21-2004, 12:33 PM   #117
Corse-R's Avatar
Default Re: pictures
Hi Uriah....
Will see you on Ft. Myers... want to talk with you and discuss some ideas regarding engines. Plan to go with Sirios or with the almighty RR12L3 you did lately?
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 01-21-2004, 01:28 PM   #118
Grinder's Avatar
Default Re: Re: pictures
Originally posted by Corse-R
Hi Uriah....
What's up, I will be in Ft. Myers, and look forward to meeting you. I think I will run the RR, but I'm still undecided because my Sirio was extremely fast down there for the warmup race two weekends ago, but there is the reliability issue with their rods. I think the RR may be perfect on that track.
Old 01-21-2004, 02:09 PM   #119
afm
afm's Avatar
Default Re: Re: Re: pictures
.............................mySirio was extremely fast down there for the warmup race two weekends ago, but there is the reliability issue with their rods........
Hi Grinder
Long time no talk...Yes I'm having same problem with my Sirio Evo2 concerning premature wear on conrod......engine is extremely fast but.......conrods???? I just hope Sirio come up with a solution for this.
Good Luck at Winternats.
AFM
afm is offline   Reply With Quote
Old 01-21-2004, 02:42 PM   #120
Grinder's Avatar
Default Re: Re: Re: Re: pictures
Originally posted by afm
Hi Grinder
AFM
The problem is not the quality of the rod itself, but a brand new Sirio rod has too much play in it.
engine mods rjmods.net Web Links 2 12-22-2006 01:54 AM
Engine Mods Jammin'Trey Onroad Nitro Engine Zone 116 11-01-2006 05:45 PM
ENGINE MODS? zrchobbies Electric Off-Road 11 08-29-2006 02:21 AM
Need some help with engine mods...... jamiekulhanek Onroad Nitro Engine Zone 6 08-22-2004 11:23 AM
F/S or F/T - Kyosho V1R with RB X12 engine and mods dg2b R/C Items: For Sale/Trade 0 02-21-2003 06:41 PM
