Engine Mods
#76
Hey guys I want to know what everyone is using to cut there ports (like increasing exhaust timing) so there will not be any burrs left on the inside of the sleeve. I am using a fine grinding bit in my dremel. Anybody using something that leaves smoother cuts? Or is there a good technique for removing burrs?
#77
#80
Definately a lot of Palmaris Racing guys on this forum. Things keep going as they are and myself and TopGun will have to start organising Palmaris Racing cup events
Guess you have to go where the power is
#81
Originally posted by Slotmachine
Edward I bet you using a wheel cylinder hone arent you!
Just insert it in sleeve and turn around 3-4 times-it is ready.
#82
Originally posted by Pit-racer
All I know about modding engines is to leave it to the experts. I just love the results, thanks Edward!
#83
#84
About Palmaris Racing Cup, it is good idea, why not? Let's think about it. On good track with real good prizes it will boost hooby.
#90
I think this is what it is. I know the minimum size is 13 mm and open till I belive 50 mm, seems like it is. But it is perfectly fit in our sleeves. There is two kind, one is Aluminium oxise and other is Silicon Carbide. I am using aluminium oxide-it is softer and doesn't hirt chrome. Silicon cirbide will scratch chrome. It costs like $ 15.
