Engine Mods
#166
Engines sleeves and pistons will always be distorted. They wear more in one axis than on the other, therefore when measured one side will be smaller than the other. In full size racing sometimes they make the pistons allready with the shape to whish they will wear.
#167
Originally posted by ERL2004
hello Ed
My sleeve is distorted a little bit and I took it to a local mechanical place where they do the grinding. Does the sleeve has to be re-chromed? How oo I get the roundness of the sleeve back to the original shape?
The guy said I need to pay for a set of holder/clamp to do the grinding?
Which method do you use, honing or grinding?
hello Ed
If you did any serious grinding on the inside of the sleeve you better replace it!!!!!!!!!!!
#168
hello Ed
hello Ed
Just get another set out of realy good material and it will last double what you have expirienced.
We use grinding and final polishing, honning doesn't give very good surface and it is working as griding tool for piston when we are run in engines. So only grinding and polishing. People who saw my P/S sets can tell you how it looks. BTW, pistons are ground too, individualy fit.
Paul I need your adress urgent, can you please send it to me, I got something for you.
#169
Originally posted by Chewdogg
hey folks haven't heard from anybody in a while...got a ? though
Just want to know.....has anybody tried using large duration numbers for induction on a .12 engine..like 220, 230, 240. If so did you like the results?
#171
thanks for the reply about duration TG......
I know some of you guys modify carbs....has anyone ever enlarged the venturi(sp?) on the carb to like 7.5mm and just used carb inserts to adjust to different sizes like 6.5, 5.5, 5.4 and so on
#177
Originally posted by SalvadoriRacing
hey folks.....
do the piston surface finish have anything to do with exhaust gas flow????
IMO, it's a myth, but I'd like to get some fedback from the experts......
thanks!!!
hey folks.....
thanks!!!
Edward.
#178
yes, I referred to the top of piston....
i was told that polishing the top of piston (the part closer to the exhaus port), gives a better flow to the exhaust gases, but I didnt believe.......
thanks edward....
thanks edward....
#180
Hi all.
This is not really a modding question but it seems to be the right place to get a sensible answer.
I am helping someone to tune a Rossi 173R12 X3 and am having some difficulty.
So I started checking through the basics and discovered that the head clearance would not compress a piece of 1mm solder.
Removed all the shims and the clearance is 0.7mm.
Can this be right. If not, what should the clearance or compression ratio be for 16% nitro?
