Novarossi engines thread
#1187
I have a P5X and it is a two needle carb. He posted that he has a P5TX which is the turbo version are you saying this is a three needle carb?
#1188
Ok Salvadori I have shims, but they are RB shims. I'll put them on and I now have the Byrons fuel. This sucka smells really strong, but the smell outta the exhaust is like fresh cookies out of the oven. . I can't wait to drive them now after I finish installing the rest of items on my car. Thnx again.
#1189
#1190
then the settings I posted above should get ya going.
#1191
Thanks again.. Cheers!
#1192
Originally Posted by ogreasurada
Looks pretty light...
#1194
Originally Posted by suntok2
Wow
#1195
Originally Posted by HarKonnenD
Ok so I opened up my TOp engine to find two RB shims already in there. Now what? Again I'll be running 30%. SOMEONE HELP! Gotta run to the track before it rains today.
My suggestions: for a 30%, go for a #7Tc (Hot), check the size of your chamber (if you run at sea level with a 30% nitro, go at least for a 0.021" chamber height).
#1197
When I ment two I ment an xtra one just incase. What can happen then if I run it with 30% stock will there be any signs I should look out for? I'll take the head off to see if there are any shims on there.
Hope this helps
Can you measure the two shims? With out knowing what they measure everybody is pretty much guessing on what you should do. Most Nova based engines are set to run 25% fuel from the factory. They are usually setup with one shim @ .20mm and one @.10mm. To be safe most engine manufacturs recomend adding a .10mm shim to run 30%. Some people don't make this change and have no problems. But usually the ones that do this know what to look for if there is a problem. Sounds to me like you are just getting started in this hobby. If this is the case and if the two shims that are in you engine now do measure a total of .30mm I would recomend you add the .10mm shim just to be safe or run 25% fuel.
Hope this helps
Hope this helps
I'm not just getting started in this Hobby. I never ran 30% before that's all. I already have a gallon of 30% so it doesn't make sense to go spend more $$ to buy more fuel lol. Thanks for the info though.
#1200
Sorry HarKonnenD! My bad I guess I should have read all your posts and looked at your post count. I hope you get it worked out!
