Like Tree195Likes
Novarossi engines thread
Old 02-02-2006 | 06:10 PM
  #1171
SalvadoriRacing's Avatar
here is the problem..........when you go to tight with head clearance detonation may occur and the visible result is the top of the piston and combustion chamber popped........in this case the damage is done and your engine will never perform as good as before until you change piston/liner and combustion chamber.........
sometimes when you're lucky the glow plug burns itself and it's a sign that the head clearance too small, or your carb setting is too lean.......then you just have to replace the glowplug and check the carb setting and head clearance.......
SalvadoriRacing is offline
Old 02-02-2006 | 06:26 PM
  #1172
HarKonnenD's Avatar
YIKES! So, atleast put one .1mm shim on there just to play it safe and richen the HSN?
HarKonnenD is offline
Old 02-02-2006 | 06:37 PM
  #1173
yep.....if want to be safe add one 0.1 shim.........
about the HSN comparing 25% to 30% nitro you usually set rich with higher nitro content......but it's a slight difference, not related to be safe or not, just because higher nitro content increases explosion and build more heat in combustion chamber
Old 02-02-2006 | 07:04 PM
  #1174
HarKonnenD's Avatar
Lightbulb
So by how much would I have to richen it up? Just basically tune for performance right?
Old 02-02-2006 | 07:07 PM
  #1175
Leo V.'s Avatar
Default LL3 Bearing
Could someone post the exact measurement of the LL3 main bearing?
Leo V. is offline
  #1176
yep
Old 02-02-2006 | 07:12 PM
  #1177
ogreasurada's Avatar
Looks pretty light...
ogreasurada is offline
Old 02-02-2006 | 07:23 PM
  #1178
HarKonnenD's Avatar
Wow, what engine is that?
Old 02-02-2006 | 07:26 PM
  #1179
11.5 x 21 x 5 mm
Old 02-03-2006 | 12:28 AM
  #1180
Originally Posted by OrAnGe PoWeR
Hi guys! Does anyone know the factory needle setting for the NOVA P5TX Buggy engine? Thanks in advance!
Guys, help please.. anyone?
OrAnGe PoWeR is offline
Old 02-03-2006 | 02:38 AM
  #1181
my engine tuner (20+ years nitro engine building)
said pretty much all engines are 2.5 turns out on high speed
and 2 1/4 turns or flush on thelow end
mrgsr is offline
Old 02-03-2006 | 02:43 AM
  #1182
Default novarossi N12 LL3 .12 turbo
heys guys
what do u think of the novarossi N12 LL3 .12 turbo ?
how do the microcast internals last ?
are there any advantages/disadvantages with this engine ?
John
mrgsr is offline
Old 02-03-2006 | 06:51 AM
  #1183
SpeedBump57's Avatar
5 out on the bottom and 3.5 out on the top should have
you in the ball park
SpeedBump57 is offline
Old 02-03-2006 | 02:25 PM
  #1184
He has obviously never touched a nova based engine before
Rody is offline
Old 02-03-2006 | 02:43 PM
  #1185
indeed.......
i checked an engine here and the LSN is 4 turns open.......
and the HSN is almost flush, slightly open from flush.........
