Like Tree195Likes
Novarossi engines thread
Old 12-13-2005 | 01:31 AM
  #1126
Do any of you guys know the factory carby settings for the N12LL3. Time to rebuild and wanna be safe..
Regards
Rody is offline
Old 12-13-2005 | 01:54 AM
  #1127
stefan's Avatar
HSN: 4.5 turns out
LSN: 2.5 turns out
stefan is offline
Old 12-13-2005 | 02:33 AM
  #1128
Originally Posted by stefan
HSN: 4.5 turns out
LSN: 2.5 turns out
Thanks mate!
Rody is offline
Old 12-14-2005 | 03:45 AM
  #1129
would 10% synthetic oil, 2% castor and 16% nitro be a good mixture. I am using coolpower for the synthetic oil
josh_c is offline
Old 12-14-2005 | 07:18 AM
  #1130
jjmudd's Avatar
A few guys here in Edmonton, Alberta bought S421B engines for our buggies but are having a bitch of a time keeping the motors running. They seem fine for the first 5 minutes and then flame out at idle. We are running 30% race blend from Sidewinder (10% oil) but it doesn't really seem to matter what percentage of nitro is used...motor does the same thing. Had a couple of guys playing with head shims...bumping up 1mm-2mm for the high nitro content but nothing seems to work.
Is this motor a dud or does someone have some tuning magic for this mill?
Thanks,
John Hughes
jjmudd is offline
Old 12-14-2005 | 08:46 AM
  #1131
rge63's Avatar
Are the engines broke in yet?
sounds like it is still tight!!!
rge63 is offline
Old 12-14-2005 | 08:51 AM
  #1132
rge63's Avatar
A little more oil is goin to make engine life longer..
alot of the manufactors are saying to use 16% oil content..I like a 14% synthetic/castor blend... no more than 4% castors more like 3%
rge63 is offline
Old 12-14-2005 | 09:30 AM
  #1133
GrandeGixxer's Avatar
Byrons fuel is 11% oil. It is good stuff. Anything over that unless you are just bashing is just going to be a waste of power. It is going to go out the pipe.
GrandeGixxer is offline
Old 12-14-2005 | 12:08 PM
  #1134
jjmudd's Avatar
Motors were borke in with 5 heat cycles in car, on the bench. Took them up to 200 deg. at 1/8 throttle and shut down to cool...repeated 4 more times and then started to run the car and lean the top to peak performance over one more tank.
jjmudd is offline
Old 12-14-2005 | 02:55 PM
  #1135
rge63's Avatar
Pull the plug out and see if it still locks up or drags at the top of the cylinder... how much fuel has run across it?
rge63 is offline
Old 12-14-2005 | 02:59 PM
  #1136
rge63's Avatar
I think your right the extra oil does take a little power away!!
rge63 is offline
Old 12-14-2005 | 04:16 PM
  #1137
jjmudd's Avatar
With the plug in there is compresion, but not so much that the motor wont turn over by hand on the fly wheel. Without the plug the motor turns freely with a slight pause/catch at TDC. The motor has seen maybe 3/4 of a gallon to 1 gallon.
jjmudd is offline
Old 12-17-2005 | 08:30 PM
  #1138
I have a Novarossi cx12ps1/n with a standard button head. I need to know if its possible to install a Turbo button from from the novarossi NS12S, into the cx12. Both have the same stroke and bore. Only differnce btwn these 2 motors is one is side exhaust and the other is rear exhaust.
vadn1 is offline
Old 12-19-2005 | 12:12 AM
  #1139
Default os turbo plugs in nova ns12s3
hey guys
just wanted to know if you can use the os turbo plugs in the novarossi ns12s3 turbo ?
thanks
John
mrgsr is offline
Old 12-19-2005 | 05:48 AM
  #1140
Default plug
i tried an os plug on a novarossi button once and it messed the threads up,and caused some burring at the top of the button .i think the treads are alittle different . now i tried an os on my mega serpent zx-12 and that worked. best bet is to use the same plug with the same brand motor
isuzuguy is offline
