Novarossi engines thread
#6121
R/C Tech Elite Member
Thanks for the help! I got it running today and it sounds fairly healthy, unfortunately the old receiver pack just doesn't have it in it anymore to work long enough for me to trust to driving.
It's definitely a Turbo Plug engine, didn't check if it was 7 ports like you said, didn't really feel like pulling the head.
The base settings 3-1/2 out on the high and 5 on the low and mid flush with the case worked well for first startup.
Short vid of it running
#6122
Hello All.
I have a Novarossi 35plus21 and a Mito 35WC. I would like to buy a spare conrod for each while they are still available. According to the manual, the Mito has an R4 (07006-17) and the 35Plus21 has an R7 (07010).
For the R7, there are so many options that I am confused. I have seen R7s for sale, both from Novarossi and Max Power, with many different part numbers, namely: 07001, 07009 , 07999. Are they all the same?
The R4, Both from NovaRossi and Max Power, is always part number 07006.
On top of that, The Novarossi Marine USA site sells the R7 as:
"07009 - .21 KEEP M, KEEP outboard, T21-5M, T21-7M and 35PLUS (same rod as 07006)"
Should I assume these rods, R4 and R7 are all but the same and interchangeable?
Thanks in advance
Thanks in advance
#6123
The R stands for the used dimensions so all R rods will fit, the number is the shape design.
The R7 has more material and the R4 a little bit less so it is called as a light rod. But then I have seen R7 rods with the shape of the R4.
#6124
#6125
Hi, I have 2 R7 rods for sale...
1 GP R7 light race rod , new in the bag
+ 1 normal R7 rod, new just used to start an rebuild old engine a few times , but the ebay nova engine cast was leaking, so I left it there
never blocked on the bench
pm me if interested....
#6126
Since I was able to get my hands on 2 Novarossi Mephisto engines I was wondering which plugs would work best with this engine. According to the manual it’s set for 16% Nitro and CT8 plug is recommended. Finding CT8 plugs are very difficult, so does anyone have any other recommendations? I do have several Reds 7 plugs but not sure if those would work.
#6128
#6131
#6132
Hello everyone.
I ordered a replacement conrod for Novarossi from an italian store (with which I never had business before), namely a Max Power MX 07006-17. The shopkeeper sent me an e-mail saying the 07006 was too weak, and advising to get the the MX 07999 instead, which he said would provide a service life of, at least, 10 litres (!!!). I replied I would take the 07999 then, and received the conrod shown in the pictures. The label is blank, it has "4.8 - 182592" engraved on it. Can anyone identify this conrod? Is it really a 07999? And, is it true than it can last as long as he claims?
Thanks in advance,
Luis Oliveira
Thanks in advance,
Luis Oliveira
#6133
195Likes
