Like Tree195Likes
Novarossi engines thread
Old 02-11-2018 | 11:09 PM
  #5491
ralphierace13's Avatar
Originally Posted by dan_vector
ok but even the exploded diagram available either online or the copy included in the box shows correct bearing orientation ie balls out the back!.
Also if you are fitting a bearing it means you most probably removed a bearing and so common sense would prevail and you'd put the new bearing in the same orientation as the one you removed. Or is that just me??
omg dan u must be slow !!! try to follow again !!! we all know balls out thanks that's not what we are talking about for the 100th time!!!! were talking abount the inner ring dam it wake up!!!! did u ever take apart a bearing ? the inner ring comes out that's what we r talking about there are no directions which way to reinstall the inner ring u got it now!!! better yet stay out the convo!!! lol
ralphierace13 is offline
Old 02-12-2018 | 12:07 AM
  #5492
Default Pipe for .12 Novarossi Flash PT
Hi guys, may i check with you guys if the Hipex 2669 is a good match with the Nova Flash .12PT ? If not, whats the best matching pipe to use for the engine?
lance04 is offline
Old 02-12-2018 | 01:33 AM
  #5493
Roelof's Avatar
To be honest it is nowhere written how to mount the bearing. It is wise to mount the new one in the same way that the old came out. And it is also the most logical way for a better lubrication of the bearing.
Roelof is offline
Old 02-12-2018 | 03:03 AM
  #5494
But that's the problem no one knows this at leat this post will make people aware of it so guys if u take your bearing out and take it completely apart take a black marker and mark the side that has to be on the outside
Old 02-12-2018 | 03:22 AM
  #5495
dan_vector's Avatar
Who actually in their right mind actually takes the bearing itself apart then reassembles it and sticks it back in the crankcase?? If it is goosed you just fit a new one from the packet and that's that.
I really don't see how you are adding to the conversation (mentioning taking the bearing completely apart) by the OP of this particular topic of his engine locking up when he mounts the backplate. It is clear he has just fitted a new bearing and I doubt he took it (the bearing itself) apart first prior to fitting it into the engine
My guess is that he simply hasn't pressed the bearing all the way home.
dan_vector is offline
Old 02-12-2018 | 03:27 AM
  #5496
well I don't question how u care for your stuff but I take apart my bearings and I change the racers before a big race so I am adding to this post to let the people that do take them apart know it must go back a certain way.
Old 02-12-2018 | 03:31 AM
  #5497
dan_vector's Avatar
Why not just change the bearing as a whole? Surely that this more sensible in retaining integrity? I have never seen anyone do anything other in 20 plus years of playing with these things.
Old 02-12-2018 | 04:27 AM
  #5498
Roelof's Avatar
The only reason why I should take my bearings apart is when it is a steel one and I have a bag full of ceramic balls. I was told the ceramic balls just cost about 11 cent a ball so that makes a cheap upgrade for the much cheaper steel bearings.
Roelof is offline
Old 02-12-2018 | 05:15 AM
  #5499
what u said roelof plus I like to take the racer out and clean the cup the balls sit in it can accumulate dirt in there... u understand now danny boy we not all as rich as u to just throw away 80 dollar bearings ...
Old 02-12-2018 | 10:50 PM
  #5500
Would love to hear some feedback on the required pipe, might have been missed due to bearing debate.
lance04 is offline
Old 02-13-2018 | 01:58 AM
  #5501
dan_vector's Avatar
Novarossi 2660 with 41615 manifold for top end rpm or 41616 manifold for bottom end power.
Old 02-13-2018 | 09:58 AM
  #5502
Appreciate your reply sir, noted with thanks!
lance04 is offline
Old 02-22-2018 | 04:15 PM
  #5503
yxiaocheng's Avatar
What is a good pipe combination for .21 onroad engine (FLASH)? Thanks.
yxiaocheng is offline
Old 02-22-2018 | 08:52 PM
  #5504
BigC2007's Avatar
I ran the .21 On Road flash all last year, but to get a good pipe and header set up its going to depend on your track size and layout.
BigC2007 is offline
Old 02-23-2018 | 07:40 AM
  #5505
yxiaocheng's Avatar
I plan on running on a 5th scale track (big and flowing). What pipe and header should I get? Thanks.
