Like Tree195Likes
Novarossi engines thread
Old 05-05-2009 | 08:29 PM
  #3196
nazwenhome's Avatar
Originally Posted by ToysRUsKid
Anyone use the exhaust gas cooler and if so, what results did you get? I want to try it but don't want to spend the money if it's only going to be used for 2 races.
i use fuel cooler (team c)as an exhaust cooler, works well to reduce a bit pressure and dissipate heat. runtime also increased about 30sec. power wise hardly feel any difference.
nazwenhome is offline
Old 05-06-2009 | 12:28 AM
  #3197
Hi there
which head gap would you propose for a Nova 359-21 running 25% Nitro @450m (1480 feet) elevation? Large fast Euro-style track.
For which symptons should I look in order to decide if I should go up or down a shim?
Thanks for your feedback!
fulcrum2 is offline
Old 05-07-2009 | 01:25 AM
  #3198
GREGORY!'s Avatar
does any one had airleak problems with the front metal seal bearings in novarossi engines?21 or 12?
it will better to use rubber seal bearing?[the ceramic one cams only with metal seal?]
GREGORY! is offline
Old 05-07-2009 | 07:20 AM
  #3199
nazwenhome's Avatar
i never had any problems with front bearing leaking with my old 3sct. if its axially shaky, change it.better safe than sorry about the rubber seal ceramic. i use boca ceramic bearings, rubber seal front(only on the outter side) and open rear bearing. i dont see any difference b4 and after changing it in this short while
Old 05-07-2009 | 07:32 AM
  #3200
GREGORY!'s Avatar
i just want to know the best 7/19/5 front bearing.metal-rubber-steel-ceramic.i am thinking that the metal will let some fuel to leak..
GREGORY! is offline
Old 05-07-2009 | 08:06 AM
  #3201
nazwenhome's Avatar
thats what i thought when i first brought my new engine. sometimes it still leaks out even when there is no free play or mechanical abnormalities. bad tuning i supposed, correct me if im wrong
Old 05-07-2009 | 07:39 PM
  #3202
fastrcracer's Avatar
Default 353 Race 12 Question
I just bought a new 353 Race 12 engine and with it came an extra needle and plastic inlet nipple. Are these just extra or are they different then the ones in the engine ?
fastrcracer is offline
Old 05-07-2009 | 08:35 PM
  #3203
Riketsu's Avatar
What version of 353 is this? 2009, 2008 or earlier? Im pretty sure the person that can share complete light on this subject would be Murnan, so I'd suggest you ask on his thread also. But maybe someone here can shed some light too.
I would think the needle is for different scenarios, like it was with the CRF.
Riketsu is offline
Old 05-08-2009 | 05:46 AM
  #3204
It is the 2008 version with the blue head, not the new purple head 2009 version.
I'll leave one on the Murnan thread also.
Old 05-08-2009 | 12:49 PM
  #3205
DS Motorsport's Avatar
The extra needle and inlet are there for if you are having any runtime issue's.
They will make the engine consume less fuel. The needle will also change the way it react's on throttle, can't say if it makes it more linear or more agressive.
DS Motorsport is offline
Old 05-08-2009 | 06:58 PM
  #3206
CanyonCarverR1's Avatar
Can someone tell me what the temp ranges are for a given glow plug on a .21 onroad engine? Cordoba on 30% if it matters.
Thx,
G
CanyonCarverR1 is offline
Old 05-09-2009 | 08:32 AM
  #3207
Renault_Tech's Avatar
i have an N12TS1/RT and was mucking around with a few spare parts i had from other engines and found that the head from the O.S TZ fits on there. The Nova head has 10 cooling fins and the TZ has 9. Could i use this head without affecting it at all? The blue from the OS looks better than the uncoloured head from the Nova....
Renault_Tech is offline
Old 05-09-2009 | 11:47 AM
  #3208
That shouldn't be a problem, It's nothing but a radiator anyway, if it fits and keeps it cool enough there is no problem.
VA_Racer is offline
Old 05-10-2009 | 09:13 AM
  #3209
What turbo plug does the 353 race 12 plus 2 use ?
Regular turbo, conical, etc ?
Old 05-10-2009 | 10:08 PM
  #3210
asw7576's Avatar
Turbo
Turbo is conical plug.
Preferably use Turbo with black body. I heard the black plug use high quality platinum coil inside ( I don't know if this claim is true or not ).
asw7576 is offline
