Like Tree195Likes
Novarossi engines thread
Old 02-17-2009 | 11:40 PM
  #3031
aussies1129's Avatar
Originally Posted by NiTrO BoOsTeR
Hey Guys i just got a quick question about some of the Novarossi plugs.
when i bought my engine off the local rep i bought 2 plugs, assuming they where for an on-road engine.
they are C6TGC Ultra Turbo, the nova website says they are for Off-road, i have a 3sct Tuned and was wondering if they will damage the engine, either they ruin the thread in the button or the piston will hit it because it is to long etc.
i havent run one yet in the engine only just finished the run in with the plug that came with which is a C#TGF (not sure what number).
Mitchell
hey yeah I got the same plugs also C6TGC and am still running it in with the C5TGF, did you find that it had some serious piston lock ? I had to get the heat gun out, I normally only do that with .21 enginesa guy is running a 3sct here I will see what plugs he is running. also are you going to change the rod after run in?
cheers
aussies1129 is offline
Old 02-17-2009 | 11:49 PM
  #3032
NiTrO BoOsTeR's Avatar
well i have put about 2L on the engine and i can just turn it over by hand with the plug in, and there is no play in the rod, i got a big race this weekend so ill check it for play after then. dont run the C6TGC in ur 3SCT because i think it will damage the engine
plug wise the ones we should have got at are the C6TGF/C&TGF/C5TGF. if you can get the O'donnell 97's or run the C#TGF or the older C#TF.
by the way how is ur 3sct going, have you run it in, and if so can you turn it over by hand with the plug in it.
Mitchell
NiTrO BoOsTeR is offline
Old 02-18-2009 | 01:47 AM
  #3033
hey guys just reading on Nova website in the manifolds section,
are Conical manifolds out for all the EFRA events,
i interpreted this through this statement "Medium long/Long/Short polished "non conical" manifold (with 6 rings) for 2,1cc On-road engines.
For use in EFRA events in 2009."
Old 02-18-2009 | 03:30 AM
  #3034
Roelof's Avatar
I can not tell for the 1/10 but I believe they are waiting on devellopments regarding new exhausts with an silencer on the stinger.
With the 1/8 you may use 20xx exhaust which are listed, you can download the list from the news selection on www.efra.ws
With the 20xx exhausts the use for conical manifolds is also back in the picture, even using with 30xx exhausts.
Roelof is offline
Old 02-18-2009 | 04:15 AM
  #3035
bigredspeed's Avatar
HI Guys, so does any one have a time when they change there O-Rings in there motors? im just curious on what signs to look for or when is a recomended time to change? just like how we change our Rods after X -amount fuel pumped through the motors, im running the Cordoba.
Thanks Guys any feed back would be appricated,
cheers
bigredspeed is offline
Old 02-18-2009 | 04:30 AM
  #3036
cheers
Im no expert but I have only changed all the o-rings once and this was on a CRF Wasp, if it seams there is an airleak replace all o-rings, also when u pull you engine down after a race if they are craked, or chipped replace them.
i dunno of a X-amount of fuel like the rod i guess when they are warn replace then
Mitchell
Old 02-18-2009 | 04:32 AM
  #3037
so just to put my mind to ease, im looking at getting a 2630 pipe with a 7 fin header and there is an option for conical or non-conical what would be the best to get.
Mitchell
Old 02-18-2009 | 05:50 AM
  #3038
ezveedub's Avatar
I don't think the "C" glowplugs will damage your engine. They have a better idle holding characteristic that favors off-road engines, but I can't see them damaging an on-road engine, unless someone knows something else between the "C" & "F" glowplugs.
ezveedub is offline
Old 02-18-2009 | 06:02 AM
  #3039
M7H's Avatar
M7H
Mitchell
conical
M7H is offline
Old 02-18-2009 | 11:24 PM
  #3040
so does anyone else think the C plugs will damage a 3sct tune
cheers
Old 02-19-2009 | 03:28 AM
  #3041
what i have found out, the performance wont be as good as it would if you were using an F. also the C is a touch longer. so im gonna trade a mate of mine who owns a hobby store and races off-road, my C6TGC's for either
C7TGF's or the C7TF
also with the 7 it will be easier to find a sweet spot. and it will run alot smoother.
Old 02-19-2009 | 09:40 AM
  #3042
JayL's Avatar
R/C Tech Elite Member
no , it won't hurt
you use the long or short body to fine tune for humidity
http://www.outlawrc.com/glowplugs.htm
JayL is offline
Old 02-19-2009 | 09:57 AM
  #3043
diesel's Avatar
Default ceramic bearings
Hi guys,
Where do you get your ceramic bearings for your engines?
I am replacing both front and rear bearings for my LL5.
Any recommendations?
Thanks.
diesel is offline
Old 02-19-2009 | 03:15 PM
  #3044
aturbotony's Avatar
Originally Posted by diesel
Hi guys,
Thanks.
try here www.murnanmodified.com
aturbotony is offline
Old 02-19-2009 | 03:19 PM
  #3045
Hi guys,
Thanks.
I have also had great luck finding engine parts at:
Kamikaze Toys and Hobbies. (a true shop for racers)
http://www.kamikazetoysandhobbies.com
madjack is offline
