Like Tree195Likes
Novarossi engines thread
Old 12-08-2008 | 09:52 AM
  #2881
I wanted to thank Novarossi for the great motors. I have been running these motors now for about 1 year and they have been awesome. My sedan has never been so fast. The power on in the infield has been great. Once again my 353 has powered me to another TQ and win. This time taking the victory in the 4th round of the Florida State Series.
Thanks again Novarossi,
DJ Apolaro
dj apolaro is offline
Old 12-08-2008 | 09:59 AM
  #2882
FF25510's Avatar
DJ,
what pipe did you used with your 353.
thanks
FF25510 is offline
Old 12-08-2008 | 11:58 AM
  #2883
2630, short header with 16% #6f plug
Old 12-08-2008 | 01:55 PM
  #2884
FF25510's Avatar
thanks DJ
FF25510 is offline
Old 12-08-2008 | 05:04 PM
  #2885
kcrunchone's Avatar
DJ did you test it with the 3501 pipe yet ?
Congrats on your TQ and W....
I have to break in my 353 fully then will be testing for best pipe for the local track then test a few pipes at 301.
kcrunchone is offline
Old 12-08-2008 | 05:59 PM
  #2886
Originally Posted by FF25510
thanks DJ
Any time
DJ Apolaro
Old 12-08-2008 | 06:02 PM
  #2887
Thanks and no I have not tried the 3501. I use the 2630 most of the time. If there is a problem with milage than I use the the 2601. If I run 25% than I mainly use the 2601 with a 7f plug and the proper shimming.
Hope this helps,
DJ Apolaro
Old 12-09-2008 | 04:25 AM
  #2888
RED-LINE M03's Avatar
Default Review
Has any tried the B2000BF if so could you rewiew the low cost Novarossi motor? It's going in a xray 808 buggy......Also what's a good pipe for this engine.
$150
http://www.amainhobbies.com/product_...ducts_id/31073
Thanks....
RED-LINE M03 is offline
Old 12-09-2008 | 10:44 AM
  #2889
musti72's Avatar
Sounds to me like you got a motor that is just broken in. Hopefully that is the case. How does the pinch feel without the plug. Does it seed at TDC nicely. Also with the plug how is the compression. If these 2 things are good than I would run the motor rich for about the first 7 tanks just to make sure of the break in and then go for the race tune. Make sure it is shimmed for the fuel %you are going to use.
hope this helps,
DJ Apolaro
hi apolaro,
i have just seen your message weirdly
the piston locks at the TDC with the glowplug. i can hear some little"blug blugs" like coming from tiny air bubbles. it is tigther than my 2 race old JLR evo3.
im going to use it with %16 fuel and im pretty sure the man who i bought the engine from used with %16 fuel
should i breakin the engine assuming that it is completely new?i use WOT method for breaking in engines
thanks for the reply
musti72 is offline
Old 12-09-2008 | 12:14 PM
  #2890
Originally Posted by musti72
hi apolaro,
Start with 5 tanks WOT on the box. Then with a soft clutch go another 5 tanks on the track. It most likely will not shift being so rich. On these 5 tanks you can lean it a little each time. Make sure to let cool down between tanks. After this rebuild the clutch and reclean the 2speed. Then put it back and start race tuning the motor.
Good luck,
DJ Apolaro
Old 12-09-2008 | 12:49 PM
  #2891
musti72's Avatar
thanks, i will
should be used with 2630 or 2601, right?
musti72 is offline
Old 12-09-2008 | 12:55 PM
  #2892
thanks, i will
Yes, with short header is better.
Old 12-09-2008 | 05:47 PM
  #2893
NiTrO BoOsTeR's Avatar
hey, sorry to sound nubbish but what is the WOT method, im guessing WOT stands for Wide Open Throttle.
NiTrO BoOsTeR is offline
Old 12-09-2008 | 07:24 PM
  #2894
You are correct.
DJ Apolaro
Old 12-10-2008 | 03:25 PM
  #2895
I would stay away from the WOT method
I found running them in nice and slow for the first 2 litres with a rich tune around the track works best, heat cycling the first 3 tanks. and not over revving them
mrgsr is offline
