Like Tree195Likes
Novarossi engines thread
Old 07-12-2008 | 05:14 AM
  #2716
Bad Mika's Avatar
Default pipes
Originally Posted by MHarrison
The 2601 pipe is a good all round pipe ( very similar to the 2602 )good low,mid & top end With best fuel mileage,the 2620 is gonna give you a little more top end over the 2601. the 2607 is a picco based pipe..if you have created a header to fit a nova motor its gonna give you alot more bottom But I find it very flat from mid to high RPMs. It does however work great on the picco motors..but again not on long straights. hope this helps
Thanks MHarisson... really appreciate your sharing
so i guess the 2620 will have slightly lesser runtime than the 2601 but have a little more top end
Bad Mika is offline
Old 07-12-2008 | 05:16 AM
  #2717
Bad Mika's Avatar
sorry, typed too fast... that should be MHarrison ...
Bad Mika is offline
Old 07-12-2008 | 05:19 AM
  #2718
Bad Mika's Avatar
Default combo
Originally Posted by stefan
When your engine runs good, you got a good one. If everybody else with the same engine / pipe combo passes you, you got a bad one.
Easy actually, ain't it?
my super new engine got passed by someone's 353 / 2630 pipe combo... my 353 with 2630 was too lame, put in a 51607 to wake it up a bit more... but still got passed
maybe i really got a bad one ??
Bad Mika is offline
Old 07-12-2008 | 09:05 AM
  #2719
Arahawak's Avatar
maybe its your fingers?
Arahawak is offline
Old 07-12-2008 | 09:20 AM
  #2720
MHarrison's Avatar
Yes, you are correct.
MHarrison is offline
Old 07-12-2008 | 09:38 AM
  #2721
Bad Mika's Avatar
well, i try to blame everything but myself haha...
but then again if my pipe is not the bad one... then maybe it's me ... cause my rctech name is Bad Mika (there's a bad in it...)
Bad Mika is offline
Old 07-12-2008 | 09:46 AM
  #2722
Bad Mika's Avatar
Default 353 rubbing mtx4r brake disk... help !
ok, on a more serious note, i think this has been asked before.
my mtx4r 'double' brake disk is hitting! my 353 carburetor and 'grinding' it off...
any problem if i were to grind off a bit of my 353 carburetor so that tha brake disk doesn't touch it anymore ? (i am not sure how thick is the carburetor wall). do not want to increase the engine height.
appreciate any advice . please help thanks
Bad Mika is offline
Old 07-12-2008 | 02:48 PM
  #2723
JetMD's Avatar
Just loosen the pinch bolt on the carb and rotate it a little bit. You shouldn't have to grind on the carb, just rotate it a little bit out of the way and it should be fine.
JetMD is offline
Old 07-14-2008 | 05:24 AM
  #2724
Bad Mika's Avatar
thanks to all for the advice.. i guess some of you guys are on a different car.
guess only the mtx4 with the very thick mugen disk brake will encounter this thing.. anyway, will try to rotate it again.. anyway, no big problem ...
thanks.
Bad Mika is offline
Old 07-15-2008 | 06:42 PM
  #2725
Arahawak's Avatar
thanks.
Change to a option single disk :P
Worst case change car!
Arahawak is offline
Old 07-15-2008 | 08:48 PM
  #2726
horizon644's Avatar
thanks.
I have this issue as well. Well, i did not rotate the the carb and such. I left it there as it is.And a small cut can be seen on the carb. after a few rounds at the track and it works fine after that. Just my 2 cents
horizon644 is offline
Old 07-18-2008 | 12:53 AM
  #2727
speedy2's Avatar
I have some airfilter oil that is
too tick and sticky
what fluid can I use to dilute it a bit ??
speedy2 is offline
Old 07-18-2008 | 05:37 AM
  #2728
wingracer's Avatar
If it is like the NoToil oil I use you can dilute it with alcohol. It comes already diluted and nice and thin but dries quickly into nice thick sticky stuff.
wingracer is offline
Old 07-19-2008 | 07:47 AM
  #2729
Bad Mika's Avatar
Default pipes...
hi, anyone got any idea where can i get novarossi 2601/51606/52626 pipe only or set with manifold online with reasonable price ?
quite difficult as many are out of stock..
thanks in advance..
Bad Mika is offline
Old 07-19-2008 | 07:48 AM
  #2730
Bad Mika's Avatar
Default pipes..
thanks in advance..
correction.. should be 2601/51606 or 52626
Bad Mika is offline
