Novarossi engines thread
#2491
Try another pipe. Fuel spitting out of the carb is a pretty sure sign that there is something in your pipe, blocking off holes and increasing back pressure (hence the fuel is blown back out of the carb.)
Had the exact same problem once and it was a piece of an silicone header gasket which did this.
#2493
Thanks ezveedub.. how about the front one? whats the size of it? I think the original nova ceramic bearing has too much tolerance making the crankshaft wobble. I might want to try TKO ceramic bearing. Has any of you tried it before? Is it tighter tolerance than the Nova one?
#2494
#2495
Thanks again bro.. I m waiting for reply mail from TKO whether they can ship international or not.
#2496
I m still having trouble tuning my Plus 21-3,i have checked my pipe and nothing seem to be wrong with it, the fuel still spit from the carb when you punch the throttle and this really up set the acceleration of my car, can someone post a good starting point on low speed needle and high speed needle turn from fully close?
#2497
#2498
Is it possible that the mule engine is a Novarossi tunned version of the ns12p3 or the new ns12ts1. These two engine are almost identical except the ns12p3 as 3000 rpm higher rev band.
What do you guys think?
#2499
Novarossi Plus 12.
Hi,
Does anyone know whether the Novarossi Plus 12-3 is a long or short stroke engine?
My son currently runs a Novarossi LL3, which is a long stroke motor & i wanted to know if the Plus 12-3 is a similar type, as his car works well with a more torquey engine.
Does anyone run the Plus 12-3 engine & how does it compare to other similar engines?
Any feedback will be welcomed.
Regards,
Everready
Regards,
Everready
#2500
Hi,
Regards,
Everready
Regards,
Everready
If i understand correctly the 12-3 is short and the 353 is long stroke.
#2501
both LL3 and PLUS 12-3 are long stroke......
the Plus version is faster due to the new shaft and the dome of the piston........
#2502
Ever since the new generation 123plus and after are all long stroke engine. There is a trend going for long stroke for 3port. But which one is more powerfull, 123plus or the LL3,,,,.....
#2503
#2504
Please if any one can help. I have been reading the postings on this thread and 3 people have asked about this engine the novarossi basic ns12ts1. If you have any information on this engine please post a reply. Need help please. I have been trying to find out if any one has used this engine and what they thought. Can any one tell if it would be good for club races or even worth the time.
