STS engines
Old 01-04-2004 | 09:15 AM
  #121
20 SMOKE's Avatar
look at the STS pipe its only $40, one piece pipe its very durable saw a car that got hit on the pipe side didnt make a mark on it
20 SMOKE is offline
Old 01-04-2004 | 09:35 AM
  #122
Manticore's Avatar
sts stops producing this pipe.
Manticore is offline
Old 01-04-2004 | 01:58 PM
  #123
dino.tw's Avatar
Nitro Tech
Originally posted by Thunder racer
i still have all the stock shims on it. Im running 16% nitro.
And the back straight is about 70-80 metres. i think its around that.
16% nitro....try 0.3mm shim first
dino.tw is offline
Old 01-04-2004 | 02:03 PM
  #124
dino.tw's Avatar
Nitro Tech
Originally posted by Top Gun 777
Very interesting moding done on.. caliper! is that Mitutoyo modded by STS?
Please send me some STS stekers and I garranty I will put on my tools them!
Nothing can not be hidden to your eyes.....
dino.tw is offline
Old 01-04-2004 | 02:17 PM
  #125
tonimccloud's Avatar
and if hec is not in stock, what do you think about the pipes I own (Sirio and Nova), or Hong Nor X12?
tonimccloud is offline
Old 01-04-2004 | 02:37 PM
  #126
dino.tw's Avatar
Nitro Tech
Nova is ok. Shark's also not bad. RDLogic perform very well....there are too many pipes,you may need to try
I only have problem with LD3's stock pipe(come with box).abnormal back pressure and hard to adjust.Also it is a bit too long so fit for small tight track.Some people use it and feel not enough top-end,so just lean it and lean it till....engine die.Then blame STS suck....
dino.tw is offline
Old 01-04-2004 | 02:44 PM
  #127
EdwardN's Avatar
So, are going to send me some stikers? Or I have to buy whole engine?
EdwardN is offline
Old 01-04-2004 | 03:15 PM
  #128
STS211's Avatar
Default sts rs5 bearing size?
hey srry to get off subjecti just wanted to know what he 2 bearing sizes are in the engine because i am going to replace them with ceramic bearings. One more question does the d5 6.5mm carb fit in the rs5 and is it worth buying?
STS211 is offline
Old 01-04-2004 | 04:03 PM
  #129
dino.tw's Avatar
Nitro Tech
Default Re: sts rs5 bearing size?
MR6801C & MR607C.
I have tested Boca on my STS for a while and work fine.
If your crank case is black old version,the new carb can't fit.
dino.tw is offline
Old 01-04-2004 | 04:08 PM
  #130
STS211's Avatar
i have the newer rs5 with the silver case. so its all good?
STS211 is offline
Old 01-04-2004 | 04:11 PM
  #131
dino.tw's Avatar
Nitro Tech
Yes.
dino.tw is offline
Old 01-06-2004 | 05:06 PM
  #132
hpinitro3's Avatar
Default About breaking the engine in.
I am going to be using 20% nitro fuel. Do i really need to change the head shims to 0.4mm?
hpinitro3 is offline
Old 01-06-2004 | 10:35 PM
  #133
jscamry's Avatar
The STS pipe are still in production, I posted a question about the pipes on Teamcrc.com, and John replied that they are still being made and in stock. Since I am planning on getting one.
thanks Jason
jscamry is offline
Old 01-06-2004 | 11:05 PM
  #134
thanks Jason
Bought mine off ebay sometime back, I think it was < US$40.
Great Stuff !!
coolracing is offline
Old 01-07-2004 | 04:18 PM
  #135
20 SMOKE's Avatar
how do you like the sts pipe so far
20 SMOKE is offline
