Originally Posted by keavze
(Post 5536192)
that much shims for 16%? :confused:
Sounds a little weird but it is true. A lot of people have tuning problem and glow plug failures (on Picco engines) because the thickness of shims is not correct. Therefore, if cannot find a correct setting on carburetor and plugs, think about the shims and it does help. Actually 0.3mm head shim thickness is Novarossi standard. |
same problem here. manifold holes are easily ripped, especially with a hotter engine like JL. I will use mugen 2501 manifolt, or nova 5fin manifolt on mine.
Originally Posted by dnitro
(Post 5539272)
That VR12 is a good pipe but the header material is to soft and wears out over time. Its a common problem. I've gone thru 3 headers, each with extra holes drilled on each side. Now I have three pipes, one header. I think nova has one that is compatible with the VR12.
thanks blee for explaining the shims :) |
You guys should give the PICCO 2607 pipe set a try, it will surely wake up the engine.
Originally Posted by Team Kamikaze
(Post 5539515)
sure will invest in one sooooon :nod: do you guys ship to ireland?????? without the mad shipping costs ;):lol: |
| All times are GMT -7. It is currently 01:22 PM. |
