Nova EFRA2652 tuned pipe
Old 03-03-2009 | 10:32 AM
blee's Avatar
Default Nova EFRA2652 tuned pipe
For using with new 353 engine.
blee is offline
Old 03-03-2009 | 12:38 PM
How does this exhaust compare with the 2630 and 2601 when used on a 353 '08?
ma_RC_el is offline
Old 03-03-2009 | 12:43 PM
blee's Avatar
Then you have to send email to ask Novarossi for detail.
Novarossi claim the best new combination is EFRA2652 + 353-09’
blee is offline
Old 03-03-2009 | 12:49 PM
DS Motorsport's Avatar
It's for the new 2009 efra specs, so the pipe makes less noise so probably less performance as well. I think you should only buy it if you need to run under the 09 efra spec, otherwise you will probably lose performance compared to the 2630 or 2601.
DS Motorsport is offline
Old 03-04-2009 | 12:03 AM
I thought the 35XX EFRA series of pipes were ment for pipes under 09 EFRA rules.
ma_RC_el is offline
Old 03-04-2009 | 01:09 AM
Pattojnr's Avatar
I thaught so too, thats why i have a 3501 on order and coming. i hope its just a number change, or this one is the thirsty equivelant to the 2630, as the 3501 was supposed to be the 3 chamber one for the 2601.
Pattojnr is offline
Old 03-04-2009 | 01:57 AM
Roelof's Avatar
With the last EFRA AGM the members spoke out their concern about the 30xx exhausts and because the 35xx exhaust have the same design the members expected the same problems. Due new designs which will be introduced from 2011 on it was the choice to go on with the 20xx/25xx design of pipes.
Regarding this one, I think the new 353 has different timings and so they finetuned the exhaust to it.
Roelof is offline
Old 03-04-2009 | 03:22 AM
shiston's Avatar
The stinger looks like a copy of the "illegal" sirio pipe
shiston is offline
Old 03-04-2009 | 04:07 AM
Pattojnr's Avatar
so where does that leave the 3501 ? they are obsolete while on order ?
so how would the 3501 compare to the 2601, im expecting a little less top speed, but maybe better fuel consumption ? and bottom end should be similar right if not just a little less ?
Pattojnr is offline
Old 03-04-2009 | 05:20 AM
Roelof's Avatar
You can better stay away from the 3501. I do not know anything about this exhaust but the 30xx (.21 engines) exhausts creates a to small band of right adjustments and so it is very difficult to finetune an engine. Also small changes in the weather can make a huge difference in the adjustment.
Beside that, the engine did run hotter (in some occasions even +20 to +30C)
Roelof is offline
Old 03-04-2009 | 09:45 AM
JayL's Avatar
R/C Tech Elite Member
the sirio was only illegal becasue they changed it from the submitted design, the specs were not.
JayL is offline
Old 03-04-2009 | 11:41 AM
KyoshokiddT.D's Avatar
the pipe is now ifmar and roar legal.
KyoshokiddT.D is offline
