Old 02-23-2012, 07:15 AM   #181
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Pipe an header
Originally Posted by mike hunter View Post
hi can anyone tell me if an exhaust and header made by novarossi for a 12 engine will fit the 12xz and the tg looking to run in both touring and pro later, are the exhausts and headers interchangable between brands. if so could you please recomend a set. the novarossi sets seem cheap if they fit. thanks for any help mike.
I ran the Os Xz Speed at this years Florida Winternats, the pipe an header i found to give the best power was the Sirio 2611 with the maxpower header motor clicked off 53mph down back straight.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 02-23-2012, 11:45 AM   #182
can you tell what is the thickness of the head shim,% of the nitro and the gearing ratio.
kyosho malaysia is online now   Reply With Quote
Old 02-23-2012, 12:18 PM   #183
Default Shimming an Gearing
Stock shimming 20% nitro 15/59 20/54 red clutch shoe, i ran the 15t because traction was high.For bigger tracks depending on traction 16/59 20/53 an agian depending on traction i play around with the diff clutch shoes.
RoninRc.com
Basher BT-4
Old 02-23-2012, 09:23 PM   #184
PinoyCali's Avatar
Default Xz rod?
Hello All,
Can I use xz rod to speed tz?
Thanks,
PinoyCali is offline   Reply With Quote
Old 02-24-2012, 09:05 AM   #185
with 20% without adding 0.1mm shim(hotter engine),that means you ran with richer engine setting,may i know what is the run time for 1 tank of fuel.
Old 02-24-2012, 09:24 AM   #186
Originally Posted by PinoyCali View Post
Hello All,
Thanks,
both with same conrod-part no:21535000
Old 02-24-2012, 09:54 AM   #187
PinoyCali's Avatar
The part# .12 zx OSM21655000 from ebay.
Old 02-24-2012, 11:21 AM   #188
21535000 is from os homepage
Old 02-24-2012, 02:08 PM   #189
PinoyCali's Avatar
http://www3.towerhobbies.com/cgi-bin...?&I=LXKFD2&P=X
For tz
http://www3.towerhobbies.com/cgi-bin...?&I=LXWPM1&P=Z
For xz
Can i use the xz to tz motor?
Old 02-28-2012, 08:17 PM   #190
is there a big difference between the OS MAX 12XZ and OS speed 12XZ specII when it comes to performance?
i am planning to use this on club racing level..
any body knows the difference between the OS MAX 12XZ model# 11670 and 11671?
by the way, is this still the latest .12 OS engine?
thanks guys!
sadig is offline   Reply With Quote
Old 04-21-2012, 04:48 AM   #191
Default os max speed xz spec 2 x3!
All my OS SPEED for sale...whoever is interested just pm me
nickiphorosn is offline   Reply With Quote
**NEW** OS Speed 12XZ engine FF25510 Onroad Nitro Engine Zone 31 02-08-2009 10:45 AM
