sirio xxv or picco jlr tuned?????
ok guys i just finished putting together my kyosho v one rrr shimo edition touring car and wanted to know what you guys think about these to engines ive came down to...i cant fined estimated hp or rpms anywhere on either but im looking for a good motor that will give the good bottom and top end...below is a link to both engines so yall know the exact ones im talking about...thanks for the help
http://www.ebay.com/itm/360419555463...#ht_2142wt_936
http://www.ebay.com/itm/230775718970...#ht_2271wt_936
over 40 views and noone can give any help???
The sirio engine will probably last longer and require less maintenance along the way. Its powerband is smoother. It will be more difficult to find parts, plugs, pipes etc as you need them along the way. If you flame out while the engine is hot, this engine may be a bit harder to restart and it usually marginal on fuel mileage all other things being equal
The Picco/JL will probably not last quite as long. The carbs on these have always been a pain in the rear to get closed all the way and the composite bottom can come loose easier. If you get this engine, shave .5mm off the center portion of the pinch bolt to make sure the carb stays tight. This engien make massive bottom end power and still makes good power thru the range although may be very slightly less on the top end. Makes very good mileage. As this engine is a bit older the rods (which are the most fragile part of this engine) may be a bit harder to find but not certain. There are a few outlets for Picco parts in the USA. The pipes are expensive, but easy to find in the USA.
Both engines make good power and capable of being competitive.
well both these motor seem to be ok can you refer a better engine for around $300 that will be competative and still have a good powerband
http://ashfordhobby.com/detail.aspx?ID=7168 I came across this and was interested. I'm a loyal RB fan, can't find them at this price point.. should be comparable. ?
go for sirio,it was more reliable than picco(picco evo4 above model not included),especially the picco conrod will give you a pain
ive found the picco for $190 new in CA so im looking at $100 dollars difference in the 2 motors
