OS Speed 12XZ engine ~~FULL PHOTO~~
#61
#62
thanks for the advice,
will attach HEC and 2630 on, will see the response next two weeks after break in.
#63
hi all,
from what i've seen, OS and picco here was really strong. im not sure about now just curious if i should be getting one of the XZ or the TZ spec2? from what i read here, TZ last long while the XZ is still a question.
#64
I am going to get a new motor but deciding between the x2 or the picco JL tuned?? any advice? Thanks
#65
for me, the xz easy tuning
btw, want to ask if the bearing on normal 12TZ can be used with 12tz spec2?
#66
#67
comparison
i.m loojking at a new engine what is the new xz like to the sirioxxx and the likes
#68
#69
How Os 12XZ performance compare to Speed XZ.I am using this engine for race.
I will buy Os 12xz not speed.I think it is better than Os tz - Top speed and torque.
Am ı wrong ?
Is xz easy to tuned ?
Thank you for answers.
Am ı wrong ?
#70
how much faster is the xz speed then the stock TZ? and is it faster then a evo3 red dot?
#71
i race os speed xz with picco jl tuned, evo4 edo mod and its almost equal in performance. stock tz 3port was not that far off.
any os engine is easy to tune own 2 of the speed version. tried with HEC turbo and jp2620, consumption is a bit more as compare to others. based on what i saw at local track, with the rite pipe such as t1050 and SAGE pipe,consumption and power wise shouldnt be a problem.
#73
#75
