Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
What to clean the internals with? >
Old 11-03-2008 | 02:13 AM
Default What to clean the internals with?
I recently picked up a fairly new Novarossi 12-SCT off a club racer. It only has about 1 gallon through it.
I have stripped it down to inspect the internals (which all look great), however I noticed some dirt on the outside, so now I am paranoid, and what to give the inside a good flush to protect my investment.
i managed to strip everything except the bearings which I have left in there as they are too hard to remove and I do not want to cause any damage.
What techniques do people use? I was planning to flush heaps of methylated spirits (denatured alcohol) and use a compressor to blow it out. do you think the bearings left in there would be a problem?
one club racer said to flush it out with fuel.
implusepro is offline
Old 11-03-2008 | 03:04 AM
Roelof's Avatar
Normal diesel fuel seems to work very well to clean engines inside and outside.
Roelof is offline
Old 11-03-2008 | 05:01 AM
keavze's Avatar
i've always used nitro...you wont go wong with that!
keavze is offline
Old 11-15-2008 | 11:48 AM
KyoshokiddT.D's Avatar
we boil our case and head in anti freez with the bearing's in it. then we clean the internals with break cleaner.
KyoshokiddT.D is offline
Old 11-25-2008 | 01:25 PM
Speyederjedi's Avatar
Same here except I use carb cleaner to clean the inside since it evaporates rather quickly.
Regards,
Speyederjedi
Speyederjedi is offline
