Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
How to remove connecting rod >
Old 09-06-2008 | 02:53 PM
Default How to remove connecting rod
I broke my connecting rod on my OS 12TZ and need to replace it. What is the best way to remove the connecting rod? I have the back plate and the head off but not sure how to get the pin out. Any help would be much appreciated.
Chirag
cpatel529 is offline
Old 09-06-2008 | 04:39 PM
Pull the sleeve out of the top of the block, and then the piston and rod. The wrist pin connecting the piston and rod is held in with circular clips. Remove one of the clips, push the wrist pin out of the piston, then install the new rod. Be sure that the oil hole in the rod and the cut portion of the piston sleeve both face the crankshaft when installed.
rcg33k is offline
Old 09-07-2008 | 09:20 AM
What is the easiest way to remove the sleeve? I am having trouble pushing it out.
Old 09-07-2008 | 04:12 PM
Speedypeterb's Avatar
put a hefty size ziptie in one of the ports when the piston is down position and your flywheel should still be on the crank and then turn it so it pushes the sleeve out. once the sleeve is out the rod will come off when its up in the case
Speedypeterb is offline
Old 09-08-2008 | 05:26 AM
RayJ's Avatar
Sometimes when connecting rods break they can damage the sleeve. This can cause the sleeve to become jammed in the case. Look up through the back plate opening and check the rim of the bottom of the sleeve. If it's not nicked or distorted you should be okay. I would using some penetrating lube on the sleeve. Spray some wd40 in through the back plate opening, and then let the motor sit upside down for afew minutes. I would heat the motor up to allow the case to expand and use a wooden dowel or other non-metal device to push up on the rim of the sleeve. I would alternate on different edges of the sleeve so that it doesn't become "cocked" in the case. The sleeve should come out.
RayJ is offline
Old 09-11-2008 | 12:25 AM
M7H's Avatar
M7H
A bit difficult with a broken conrod...
M7H is offline
