Old 08-30-2008, 09:35 AM   #31
T-ROY22's Avatar
I have a TZ .12 5port and just wanted to know whats the best overall pipe for this engine. I have a Skyline VR plus12 pipe but i heard that's restricting the eng.
T-ROY!
Mugen Seiki USA,Enneti Tyres, Murnan Modifieds, Airtronics USA
T-ROY22 is offline   Reply With Quote
Old 08-31-2008, 04:29 AM   #32
freestyles's Avatar
Trader Rating: 14 (100%+)
I have a VXR X-1 pipe connected to it but i havn't really ran it in race conditions yet so i'm not to sure on how well it's matched to the motor. I actually want to get the K-factory Missile pipe/header (#k6001) for it as i have used one before and liked it.
It would be good to know though what the exact pipe is that matches the TZ the best
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 08-31-2008, 07:08 AM   #33
lil-bump's Avatar
Trader Rating: 83 (100%+)
Go with the OS pipe 1040 L52sc or even the outlaw version of the same pipe.
I did not like the k-factory Missle pipe. extremely restrictive. I only use it on my break-in bench.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-31-2008, 07:16 AM   #34
NitroWD's Avatar
the sage pipe matches the TZ quite well too...
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 09-05-2008, 09:55 PM   #35
freestyles's Avatar
So here's the latest. I've been starting it here and there unfortunately due to lack of time or bad weather and every time i've started it i get a really erratic idle so isuppose i have to try and find an air leak somewhere but the thing that's frustrating me is that i can give it a little bit of gas no problem but when i go mid to full throttle it seems as though when the clutch engages it cuts out so my question is: Can your clutch gap be too big so when it engages there is so much force on the clutch bell that it stalls the crankshaft there for flamming out
I've never had a problem like this with any other motor and all i hear is how easy O.S motors are to tune so i'm hoping it is something else not the motor
Old 09-08-2008, 08:59 AM   #36
freestyles's Avatar
Does anyone know the factory needle settings for the TZ. I'm just having a bit of trouble getting it tuned right so i want to start again.
When i bought it off my mate the mid-range needle wasn't flush with the carby and now when ever i get to mid/full throttle it flames out. I'm hoping it's because of the mid range needle not anything else.
Every other motor i have they say keep the mid range needle flush with the carby, is it the same with the TZ?
Old 05-19-2009, 11:19 PM   #37
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Just bought this engine Today: O.S. Engines 12TZ (P) - T3, 3 Port Race .12 Engine via Kamakazi Racing - Thank you for the quick response!
I have been getting all my stuff as i am getting back in Nitro Tourer racing, i used to have the other version O.S Engine 12TZ 3 Port but not the Race port - what differance to this race port to the other?
Cheers
Frankie
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 05-20-2009, 01:45 PM   #38
afm
afm's Avatar
Cheers
Frankie
None at all it's the same engine you had, just an interpretation of the description.......
O.S. Engines 12TZ (P)-T3, 3 Port racing .12 Engine
As far as carburation goes, this engine will work flawlessly if you kep your hands out of the low end and so c alled mid ramge needles....both have to be flush with their bodies, then just tune with the high end and idle needles
The factory setting for HSN is 1 3/4 turns open from closed (for racing), and for break in 2 turns out
AFM
afm is offline   Reply With Quote
Old 05-20-2009, 11:08 PM   #39
AFM
Nice one AFM,
hey what you recommend as a pipe and manifold and plug?
Turbo OS plug No#6 - also anyother plug makes can go into the OS? Nova?
Manifold: Conical 5 fin or 6 fin?
Exhaust: 2601 or 2630 Novarossi?
Cheers fro your help mate - every little bit i take iin....
Regards
Frankie
Old 05-20-2009, 11:18 PM   #40
GREGORY!'s Avatar
Nice one AFM,
Regards
Frankie
take a look in the top of this thread.
i think that will be better to stay with os 1040 pipe.
GREGORY! is offline   Reply With Quote
Old 05-20-2009, 11:52 PM   #41
Cheers on the info - red the whole thread but no one has mentioned any of the Nova pipes...
Kamakazi has this pipe:
Product ID: T1050SCL52
OS SPEED T1050 L52 TUNED PIPE SET
This is an O.S. Max Left Side Tuned Pipe set for .12 to .18 size engines, The "SC" stands for "Spring Connect" which means it uses springs to attach the Tuned Pipe to the Header. Polished natural aluminum construction
Anyone used this pipe?
Id like to get the pipe that will work well, i used to run the TZ about 2 years ago with a Nova 2630 it seemed ok, but i am still learning on how to tune a engine right let alone make it last.....
Also with the NEW once i get it started is it best to place a heat gun for break-in to get some temp into the head before i crank it over.....
Cheers for any advice
Frankie
Old 05-21-2009, 12:24 AM   #42
jca2000au's Avatar
Trader Rating: 9 (91%+)
Frankie
I do and it is only pipe that make TZ and XZ sing !!! you can forget T-1040 only top end pipe, T-1050 is heaps of bottom end.
jca2000au is offline   Reply With Quote
Old 05-21-2009, 12:59 AM   #43
PROVK's Avatar
Cheers Also with the NEW once i get it started is it best to place a heat gun for break-in to get some temp into the head before i crank it over.....
Frankie
You sure do Fuji
George V
Mugen Seiki
Max Power Engines GRP Tires Nitro X Fuels "Mugen Blend"
www.rrcsa.org.au
PROVK is offline   Reply With Quote
Old 05-21-2009, 01:03 AM   #44
$300AUD for a pipe set eeekkkkkkkkk
Old 05-21-2009, 01:12 AM   #45
PROVK's Avatar
You sure you havent got a 2 in your cart
George V
Mugen Seiki
www.rrcsa.org.au
NIB O.S. .12TZ EB Mod kalani R/C Items: For Sale/Trade 2 09-30-2008 05:00 PM
<<<<<<$NIB O.S. .12TZ T3 FS/FT$>>>>> joelg R/C Items: For Sale/Trade 6 04-08-2008 04:23 PM
TM G4S w/ OS 12TZ! hooked_on Australia For Sale/Trade 7 09-28-2007 04:01 AM
OS 12TZ(P)-T5 12 nero1943 Nitro On-Road 1 07-14-2005 05:48 AM
OS .12TZ(3T) Vs STS D3R spyspeed Onroad Nitro Engine Zone 0 05-20-2005 07:29 PM
