O.S .12tz any good???
Old 08-12-2008 | 10:40 PM
  #16
freestyles's Avatar
What size venturi were you guy's running? The size that came with my car measures 5.30mm so i'm not sure if it's stock or an option
freestyles is offline
Old 08-12-2008 | 10:48 PM
  #17
Team Kamikaze's Avatar
That is stock (Legal)
Team Kamikaze is offline
Old 08-13-2008 | 02:45 AM
  #18
freestyles's Avatar
Cool, can't wait to get it on the track. I have almost finished rebuild/set up after buying it so i am keen to see how it all goes. I'm sure i will be happy though i will post some feedback on how it went.
Old 08-18-2008 | 04:15 PM
  #19
fastharry™'s Avatar
From: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
whats with OS?....no 5 port tz?....no hot engines except for that 400 dollar stage 2?.....are they gonna make anymore 12's?
fastharry™ is offline
Old 08-18-2008 | 05:11 PM
  #20
dnitro's Avatar
Take your time during break-in because it is one of the most difficult engines to break in. Make sure your starter box is fully charged and have a flat head screw driver ready to run the flywheel when it gets stuck at tdc.
Not only are they good engines, to rebuild it will only cost you $60-70 bucks. Other engines can cost over $100 to rebuild.
dnitro is offline
Old 08-20-2008 | 12:19 AM
  #21
freestyles's Avatar
HUH??????
I think it has already been broken in though i bet to find out for sure before i go nuts with the tuning driver
Old 08-20-2008 | 02:51 AM
  #22
freestyles's Avatar
How many head shims are you guy's using. I'm running 16% nitro through it with an RB 6 turbo plug
Old 08-25-2008 | 03:14 PM
  #23
freestyles's Avatar
The motor came with a red clutch spring, do you recomend to use that one or i have a slightly smaller silver spring that has come in another kit that i could use aswell. The reason i say this is because i started it up on the weekend and the second it kicked over it started pinging off it's head and the clutch was engaging while the wheels were off the ground. When i took the clutch apart i found the clutch spring had to much tension on it, so i backed some off. But when i was putting it back together it felt like the red spring was to hard for the set-up. Should i change it with the smaller silver one or should it be ok??? I'm just hoping that this was my problem not some other under lying problem i can't see yet.
Anyhelp would be great as i really want to get the best out of this mill.
Old 08-27-2008 | 11:02 AM
  #24
RC MARKET's Avatar
new series coming !
RC MARKET is offline
Old 08-27-2008 | 11:40 PM
  #25
freestyles's Avatar
Originally Posted by RC MARKET
new series coming !
HUH
Old 08-28-2008 | 01:11 AM
  #26
chippy's Avatar
new series coming !
I think he means the next generation of OS motors is coming out soon
The new model they ran at the 200mm worlds
chippy is offline
Old 08-28-2008 | 05:51 AM
  #27
itchy b's Avatar
Are you guys getting more engines chip?
itchy b is offline
Old 08-29-2008 | 01:12 AM
  #28
freestyles's Avatar
Don't know much about O.S, have you got any more info on this new line up?
Old 08-29-2008 | 03:06 AM
  #29
chippy's Avatar
What do you mean more engines
Only got 2 new ones at the moment.
chippy is offline
Old 08-29-2008 | 03:08 AM
  #30
chippy's Avatar
No not much info only the pics that where posted on Redrc
chippy is offline
