JP 21-3 Black Piston sleeve
does the Novarossi 21-3C (code 08550) Piston Sleeve Conrod fit in the JP 21-3 Black?
anyone?
I got a JP FX 21 R-03 from a friend and he gave me a novarossi piston/sleeve/rod that he had bought for it. I guess it will work but like I said, I didn't research it but I don't think he would of spent the money on it if he wasn't sure it would fit. It is p/n NOVA 08542. Hope that helps.
The 21-3C is from the Plus series. Although the boring/stroke is the same it does have another size crankshaft (14.5mm) and is there a slight possibility that the sleeve will have another fitting as well.
I did make a N21-3T set fit into a JP RX1-WC2003 crankcase without any problems.
