How do you adjust engine timing on nitro engines?
#196
Very interesting; a couple of matters that I would like to learn more about:
1. Which areas should be roughened up with sandpaper for better flowspeed?
2. What is pumping effect of the crankcase?
3. Do you have a download link to the book that reloaf has recommended?
Any advice of would be greatly appreciated.
Kindest regards,
Lars.
Kindest regards,
Lars.
The link:
http://edj.net/2stroke/jennings/
#197
Pumping effect: basically on a two stroke, the crankcase acts like a fuel pump and since the air is involved too, sort of like a supercharger as well. The higher the compression ratio in the case, the more the effect though higher ratios also mean less volume so you lose on volumetric efficiency so around 1.5 to 1 seems to be the magic number.
The link:
The link:
Kindest regards,
Lars.
#200
I'm trying to mod my older TN12 up. The piston/sleeve/Conrod are all good. The piston reaches the top of the sleeve with 1.5-2mm left before the piston stops. The rod also doesn't have any play.
From Steve Pond's article, I see that front port is smoothed out, but what about the exhaust port? Where would that be modified? What about the little groove on the crankcase, should I smooth that out a little bit? And what about the crankshaft inlet? How much material can be taken off a .12 piston safely?
I want to do this and am not worried about damage, but I'd like to do this correctly, or close, the first time.
#202
If you are looking to improve top end with a simple proven and reversible solution, place a shim under the sleeve´s edge and the seating area on the cranckcase, that way you´ll increase total exhaust timing giving you more top end. start with a 0.10mm shim. Don´t forget you´ll have to re-shim the combustión chamber accordingly, that is remove same amount of shim 0.10mm
AFM
AFM
#203
And what about the crankshaft inlet? here is where you get the most notorious engine improvement. Induction timing works like this: earlier opening = more low end . Later closing = more top end.
Also keep in mind that the greatest boost in power is gained by increasing total induction duration, and increasing inner diameter of passage in crankshaft.
How much material can be taken off a .12 piston safely? stay away from this option.
AFM
#204
I cleaned up the front port, bottom of the sleeve, a tail groove on both side ports, I cleaned up the crank groove, and roughed up the inlet port on the front of the crank. I actually used a file in there, just a couple rubs nothing crazy. I kept reading about turbulence for better mixtures.
If it runs like crap oh well.
#205
I would like to thank all that have posted info on this thread. It has helped a lot. I built an angle finder like Stefan posted using a 5 mm pinion gear glued to the back. I also made a piston stop to get TDC . I first Modded a Sportwerks .26 . I ground away the bridge at the bottom of the intake runners to match a Novarossi I had. I then sharpened the bottom of the sleeve. I didn't touch the ports on the liner but I ground on the crank to make it close at 65 degees after TDc with a 215 duration. It runs awesome I tried it in my driveway and I thought it was going to tear the driveline out of the car. I have a lrp 30 x I was going to do and it doesn't need alot . Maybe a couple degrees on the closing of the crank as it closes at 62 degrees. I wonder how thin I can go on the Crankshaft before it would break? It is 14 mm and the hole in it is 10.5 mm. I was thinking about going to 11mm. Fuel mileage isn't a concern.
#207
On this question I will answer for you-do not cut bottom edge of exhaust windows. If you cut and it will open while piston in Top Dead Center your engine will have decompression of crankcase, it will mess up all your timings, millage and power. What is the reason you want to cut it> do you think if you make smoother pass for better flow it will run better? It doesn't work that way, it is not sewer pipe with shit flowing in it, there are many processes involved, including sound wave, so that "smoothing" will do nothing in terms of better flow. But decompression will kill your engine performance, specially with tuned pipe. But I can guarranty you, it will work much better without tuned pipe.
#208
BTW, too many new faces here and most of them didn't read all our materials in 2004-2006 time frame.
Here is trick for you-if you want to change exhaust timing, or transfer timing and don't feel comfortable to mess with sleeve, you can do it change without touching sleeve. You can cut piston correspondent to port segment. Search somewhere in my tread Palmaris Engines ( http://www.rctech.net/forum/onroad-n...ne-thread.html ) and you will find good pictures there how it is done. I did many many times. I know it is a lot of reading and searching, but it worth it.
#209
Here is the wiki page on nitromethane.
http://en.wikipedia.org/wiki/Nitromethane
As you can see from this info, nitromethane is explosive. Also, since it is an oxygen carrier, it requires less oxygen to burn. Since we don't usually reduce the carb venturi when going up in nitro % this will require a richer needle setting (same amount of air will require more fuel) therefore fuel mileage is reduced.
I have to agree with Roelof that more nitro is easier to tune up to a certain point. It will be much easier to tune a motor on 30% nitro than it will be on 5%. However, it would probably be quite difficult to tune them on really high % nitro simply because our motors are not designed for it. Now if we increased head volume and made numerous other changes it would probably work OK but no one I know has ever tried it.
3Likes
