OS Max .28
Old 06-22-2007 | 01:19 PM
German Muscle's Avatar
Default OS Max .28
anyone got any further info on this?
German Muscle is offline
Old 06-23-2007 | 12:01 AM
Kemorc's Avatar
its a 5 port (or so they say), and knowing GPMD, they are going to jack up the price on it and try to make a killing off of it.
Kemorc is offline
Old 06-23-2007 | 04:52 PM
is that mid block or normal block? looks nice...but will probably be all sorts of high priced lol
NitroLuver is offline
Old 06-24-2007 | 12:00 AM
big block
Old 09-04-2009 | 12:47 AM
ScottyM's Avatar
Old thread, and sorry to revive it.. I have a question for those that have run it though.. I had a problem with mine wearing the brass bushing on the conecting rod, crankshaft side.. Also when I tore it down I measured the crank pin, it had .0055" roundness, and .011" taper from rear shoulder to edge of pin.
OS wouldn't give me any info weather it was okay or not.. I know it is bad. But curious if anyone else has run into this problem, and what all has been done, if anything, to fix it..
ScottyM is offline
Old 09-05-2009 | 10:51 AM
pull the piston and rod out and check the bearings and see if there is any play. This isnt common on these engines. How much fuel has been ran through it?
