JL Racing .12
#1801
#1806
I cleaned the carb and the sleeve, spread some jb weld on the inside of the metal sleeve and put it on the plastic carb neck. I also filled the two small holes which were previously occupied with the plastic pins with jb weld. The bond seems strong...
g
#1807
While trying to pull out the carb, i forgot a piece of the pinch bolt and broke the plastic pins holding the metal sleeve of the carb neck.
g
g
#1809
I have a problem with the red dot evo3, with manifold! its bigger than others an i cant fix up the lexan.... Is that normal????
#1811
and what i have to do???
NOTHING???
NOTHING???
#1814
I just bought my first Picco JL tuned version Red Dot. Ive heard lots of bad things about Picco but Ive seen them run, and Ive seen a couple of top drivers run them and these things scream. My question is I want to run 30percent. What shim do I have to add or what should the clearance be? Also, Ive heard that the skyline pipe works well with it but is there a best choice for this motor when it comes to exhaust. Any other input would much appreciated. Thanks in advance!
