JL Racing .12
#151
Originally Posted by afm
You may want to adjust the shims of the combustion chamber depending on nitro-content (see table)
Nitro content: 16% 20% 25% 30%
Head shims: 0.40mm / 0.40mm / 0.50mm / 0.60mm
Large tracks may require an extra 0.10mm shim to reach higher top speed and improved fuel consumption, but this will decrease acceleration slightly.
TURBO COLD GLOW-PLUGS to use when humidity is below 70%
•P5TC hot filament
•P6TC medium filament
•P7TC cold filament
TURBO HOT GLOW-PLUGS to use when humidity is above 70%
•P5TH hot filament
•P6TH medium filament
•P7TH cold filament
The filament number will depend on the ambient temperature. Colder use hoter filament. Hotter use colder filament.
AFM
•P5TC hot filament
•P7TC cold filament
•P5TH hot filament
•P7TH cold filament
AFM
#153
Let's clear this out.
AFM
AFM
#154
Originally Posted by rcrevolution
so the JLR is based off of an older design?
that translates to SLOW for me
RC_Alan
#155
I'm sorry about my last post... You were just joking about the JLR being slow... I got it now... Good one...
RC_Alan
#156
It will, and even outperform the ones you mention, and you may include JP's, Sirio's and Fantini's. At least mine does here at my track.
AFM
AFM
I am curious to know how high above sea level you have been using your engine, AFM.
I am not suggesting altitude will make it a bad engine. Not at all!! I would only like to know since many places in Peru are extremely high!!
Thanks!!
#158
Thanks!!
Thanks!!
Our only serious track is located in Lima (sea level), see our association's web site www.apercar.com, and after every race results of last year's there ar lost of pictures.
AFM
#159
RC_Alan
RC_Alan
AFM
#160
Jokes aside, the latest Picco Evo3 is not even for sale yet, so the JLR is based on top Picco available engine, and I wouldn't be wrong to say that soon after the Evo3 is released there will be a JLR II or something like that....constant evolution my friend....so just rip the tracks with the current one......by the time you can handle its power, a faster version may be available.....jejejejeje
AFM
AFM
#161
Eventhough Peru has cities at altidudes as high as 3,200 mts (Cuzco), I've only run engines in Arequipa at 2,400mts, and the best engine I've run at that altitude is the OS TZ.
AFM
AFM
Thanks!
#162
How do you think the JLR will perform at 2400 mts?
Thanks!
Thanks!
AFM
#164
I plan on getting a JL Red Dot soon, but a friend of mine was telling me that I should change the rod after break-in. Does anyone have any feedback on this? Is this something I should worry about?
#165
additional commentreason for edit)
But if you want to play it safe, replace it every 2 gallons, specially if you have abused it.
