Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Help with pipe manifold combo >
Old 10-29-2021 | 05:41 PM
Default Help with pipe manifold combo
Hi, I'm running a mephisto .12 on a large 1:5 scale track. What pipe/manifold combo do you reccomend?
tc3thatflys7 is offline
Old 11-01-2021 | 10:13 AM
Roelof's Avatar
If you are really talking about long straights then you can go 2 ways....
1) advised pipe with short manifold. Brings up the RPM high.
2) advised pipe, long manifold, larger pinions. Lowers the RPM a tiny bit but will boost some torque that you can use with larger pinions (or smaller gears).
Roelof is offline
Old 11-01-2021 | 06:19 PM
Thank you
