Kyosho Fazer not getting fuel - odd issue?
Hi all.
Having issues with my Kyosho Fazer ( shorturl.at/huzS9 ). It seems as if there is no fuel reaching the motor, unless I blow down the pressure pipe.
So far, I've had the exhaust off, the exhaust manifold off and the header off, sealed everything with gasket maker. When I am blowing down the pressure pipe (pipe from exhaust to fuel tank) the car runs without issue. The minute I put the pipe back on to the exhaust, there is no more fuel.
Could it be a jetting issue? Or is it something else that might be the issue?
You need to prime the engine to get fuel to the engine to start. Once it starts it runs on it's ;own pressure. Block the exhaust stinger until it fires up.
I've done that, primed the engine, blocked off every hole possible. On my other car, I prime the engine, pull the starter a few times, and off it goes, on this one, it only runs when I physically blow down the pipe leading from the exhaust to the fuel tank...
Make sure the pressure fitting isn't blocked. Open the carb and see if blowing in the pressure line to the tank if fuel goes into the carb.
When I blow in to the pressure line, the car runs fine, if I keep blowing, the engine keeps running... If I connect the pressure line to the exhaust, prime the carb, start the motor, it cuts out once whatever fuel was in the fuel line, is gone.
Probably dryed up oil in the carburator.
