Like Tree8Likes
  • 1 Post By kawasaki161
  • 2 Post By Roelof
  • 1 Post By fyrstormer
  • 1 Post By 3DFLYER
  • 1 Post By UrabusDenis
filter oil
Old 04-23-2021 | 07:55 AM
choisan's Avatar
Default filter oil
any substitute from auto repair shop?
choisan is offline
Old 04-23-2021 | 08:16 AM
1/8 IC Fan's Avatar
I used ATF fluid in a pinch before...
1/8 IC Fan is offline
Old 04-23-2021 | 09:09 AM
choisan's Avatar
how about motor oll that i used inside engine? the filter oil is to prevent/stick the dust, right?
choisan is offline
Old 04-23-2021 | 09:11 AM
Suspended
If they also carry products targeted at motorcycles chances are they also have some sort of air filter oil, though it's usually a lot thicker than what's commonly used in the on road sector, some of the off road guys use it, mainly because you can buy a can of it and never again worry about it running out. Chainsaw bar oil also has very similar properties (very sticky).
2 stroke oil should also be usable if you're looking for something that's a little thinner viscosity.
choisan likes this.
kawasaki161 is offline
Old 04-23-2021 | 07:10 PM
choisan's Avatar
2 stroke oil means the motor oil for 2 stroke motorbike? i am no expert in bike
choisan is offline
Old 04-24-2021 | 01:53 AM
Suspended
Correct, the stuff you use for pre-mix.
Old 04-24-2021 | 02:25 AM
Roelof's Avatar
Basically any oil will work better than no oil. Even some RTR brands advise to use afterrun oil which I also o for many years.
A good and very stickey oil is from Putoline called Action Fluid and is special for foam filters. It also comes in a handy spray can.
https://www.putoline.com/en/catalogu...on-fluid/1659/
nitrodude and choisan like this.
Roelof is offline
Old 04-24-2021 | 03:15 AM
fyrstormer's Avatar
I use Team Associated air filter oil. Soaks in easily, then thickens to be incredibly sticky, so it won't get sucked into the engine and leave the filter dry. Also it doesn't degrade foam sponges like some air filter oils I've seen. But as roelof said, in an emergency any oil is better than none.
choisan likes this.
fyrstormer is offline
Old 04-25-2021 | 03:53 PM
3DFLYER's Avatar
I've previously used after run oil also when racing offroad nitro buggy way back when.
Ive followed tips from Jeff Hamon and oil from inside and let it soak to the outside also
choisan likes this.
3DFLYER is offline
Old 04-25-2021 | 07:39 PM
fyrstormer's Avatar
Airflow through the filter will draw the oil to the inside of the filter over time. Soaking the filter from the inside may produce a more visually-satisfying oil saturation, but it won't produce better filtering, since the air has already been cleaned by the time it reaches the innermost part of the filter. It is likely that any oil applied to the inside of the filter will get sucked into the engine the first time you rev it to full-throttle -- especially if the air filter is very close to the carb inlet and is getting damp with fuel splashing out of the carb at idle.
Old 04-27-2021 | 02:20 AM
UrabusDenis's Avatar
Motocross air filter oil is the proper stuff. Any brand will do!
choisan likes this.
UrabusDenis is offline
Old 04-28-2021 | 02:52 PM
lil-bump's Avatar
I've used Notoil oil filter for motorcross bikes but it was a little to thick. It caused tune issues. I only use the Novarossi airfilter oil. while its still around????
lil-bump is offline
Old 04-28-2021 | 03:49 PM
Suspended
It is not hard to use too much in the case of Motocross filter oil, especially because the on road foam is black so you can't guess the level of saturation very well. The foam being permanently attached to the rubber piece doesn't help much either as it makes removing excess oil more difficult.
It's perfectly fine to use once you get the hang of it though.
choisan likes this.
Old 04-28-2021 | 11:56 PM
True, you can get it wrong - coming from off-road and white filters, this was a struggle initially. But it's really simple, just put large drops on a few places and gently massage it, not to rip the foam. With a strongly coloured oil (mine is very deep blue) you will easily see if there's any blank spots left. Then wipe it off (very very very important) and leave it for a while. I'd never oil a filter at the track and put it on, I prepare them weeks in advance as a part of regular maintenance.
BTW for me it's even worse with Novarossi oil (I have it), because it's without color and thicker than my Twin Air motorcross air filter oil (still very tacky)
choisan likes this.
