Sirio evo 4 engine settings
Hello, good morning, I am Mario, a pilot from Spain, I was looking for advice on Sirio 12 engines, I have an evo 4 and I wanted to know some adjustments for its proper functioning, such as the height of the combustion chamber, average screw turns and low, over what temperature range does it work and what leaks are adequate and on the other hand if the sirio 2015 have solved the problems that I understand of quality since I have read that the rear bearings were of poor quality and the difference with the xrd which I understand are Syrian base. Thanks and best regards, gas thoroughly.
