Nitro Running HOT
Old 03-27-2006 | 09:28 AM
Nitro Running HOT
I hope somebody can help me I'm a rookie in the Nitro world I have a Acme .15 motor I'm using Track's 10% Nitro fuel I think it's called Red Alert.. I have broken in the motor and tuned it to the best I could with the info that came with the motor. It is running around 260 to 280 heat wise I have a number 8 glow plug med to hot.. I have good smoke coming out of the pipe so it's running rich. What can I do to fix this????
ChaseRacing is offline
Old 03-27-2006 | 11:51 AM
Riketsu's Avatar
Get a better fuel (different fuel), open up the top-speed needle and check for airleaks.
Riketsu is offline
Old 03-27-2006 | 06:09 PM
Speedypeterb's Avatar
is the body cut out for cooling and also make sure the car is running free and not binding
Speedypeterb is offline
Old 03-27-2006 | 07:15 PM
Hi!
We need more info, what you mean with ACME engine.
Some engine do run at 280*
So in order to help you we need more info about the engine and in what you are running it.
Edgar Millenium is offline
Old 03-31-2006 | 04:51 PM
Just for future reference for ya, hotter plugs cause the car to be ran at a lower temp and richer mix, colder plugs cause higher temp and a leaner mix. You get a little more power from a leaner mix in any combustion style engine, but sacrafice lenght of life. I personnally run my car with a super hot plug and a very rich mix and I don't notice a difference in the power. If you are going to run a hotter plug and richer mix, while tuning you don't want the car to hesitate when you punch the gas.
Switch to a hotter burning plug then run that bad boy rich, unless of course that is the normal temp for the motor.
spcards30 is offline
Old 04-01-2006 | 08:46 PM
ProudSavageOwnr's Avatar
i had an engine running around 320 and nothing happened to it.....try getting some 15% or even 20% nitro..itll run abit cooler..and richen it out like 1 turn 1/2 turn and get an os a3 plug
ProudSavageOwnr is offline
Old 04-03-2006 | 11:11 AM
SpeedBump57's Avatar
IMO the 10% nitro is just not enough for the .15. You should be running 20% as most do with .12 to .18. The hgher nitro content will help cool the engine because you will be able to get the same power as with lower nitro content but with a richer fuel mixture hence the lower temps. Byrons makes a good 20% fuel as do others, I run Byrons.
SpeedBump57 is offline
