Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
.12 engine reducer 6.0 vs 8.0 >
Like Tree1Likes
  • 1 Post By Roelof
Old 09-10-2019 | 07:59 AM
Default .12 engine reducer 6.0 vs 8.0
what are the pro and cons? Live in southeastern states. Just parking lot driving drag 132ft.
lighttravler is offline
Old 10-08-2019 | 10:43 AM
British Menace's Avatar
There is only so much fuel/ air mixture an engine can draw through the carb and into the cylinder. If the reducer is such a size that this maximum has not been reached then a larger reducer will allow more air into the carb and hence get closer to the max the engine can handle given it's capacity and port timing's. More power!
So if a 6mm reducer restricts this flow. Going to a 7mm will give you more fuel/air and more power. If 7mm give's the engine the maximum air and hence fuel/air mixture available to be drawn into the engine. Then going to an 8mm reducer will not do much. No extra power.
Again. This is given the same port timings and sizes in the engine as these could well then be the restriction the engine has against attaining it's max power output.
Don't forget. Extra air passing through your carb will need more fuel ! So the bigger reducer will cause a greater fuel consumption.
Hope this helps.
Regards
BM
British Menace is offline
Old 10-12-2019 | 11:21 AM
Ok thanks for the explanation. .12 is modded but I see a couple of factors play a role i see.
Old 10-12-2019 | 12:27 PM
Roelof's Avatar
Maybe I am wrong but by racing rules the hole in a .12 carb is limited to 5.5mm. Drilling it up to 6mm can be dune but up to 8mm...?
Roelof is online now
Old 10-13-2019 | 04:32 AM
I have picco reducer you to 9mm no drilling required and it fits. Just was looking some input
Old 10-13-2019 | 05:34 AM
1/8 IC Fan's Avatar
As previously stated by others you are more than likely not going to gain anything by running a carb reducer past the recommended manufacturer specs. Your engine is just going to burn more fuel, more inefficiently. What is the actual carb I.D. ? There is only so much you are able to do with a motor, and some times diving off the deepend just creates more problems...
1/8 IC Fan is offline
Old 10-13-2019 | 08:13 AM
Roelof's Avatar
Are we talking about a .12 or a .21 engine???
Again, no normal .12 engine has an carburator larger than 5.5mm, even if you put in an 9mm restrictor the hole will still have a maximum opening of 5.5mm.
1/8 IC Fan likes this.
Old 10-14-2019 | 04:32 AM
.12 and I got you.
Old 10-14-2019 | 01:11 PM
Julius's Avatar
for some carbs this is correct. For the picco however the opening in the carb is much larger than the restrictor. So a larger insert will give a bigger opening.
strange but true.
Julius is offline
