Ninja Engine by GRP
Old 06-15-2007 | 06:31 PM
  #901
wallyedmonds's Avatar
Originally Posted by kreamUNO
whats the best pipe and manifold to really bring out the power of this engine?
the ninja pipe and manifold
wallyedmonds is offline
Old 06-15-2007 | 07:00 PM
  #902
Wolverini's Avatar
I don't know which one you're talking about but I run the MR21BO1A with a Tsais T32X and it is A-freakin-mazing!!
Wolverini is offline
Old 06-17-2007 | 07:31 AM
  #903
HarKonnenD's Avatar
Some guys say running the Ninja with 20% or 25% is as fast or better than using the 30%. Is this the myth I been thinking of for the longest while that 30% really isnt necessary except for 8th onroad? Also, since I plan to get one I'll be going with Rocket Science 20%. Now the rule of thumb to step down to a colder plug when using 30% say for example a #7 can this same plug be used with the 20%? Any removal of shims needed?
HarKonnenD is offline
Old 06-17-2007 | 08:39 AM
  #904
Corse-R's Avatar
Are you talking of a .21 or a .12?
If I suppose, you're talking of a .12, if you want to go with 20%, switch to a #6 plug (hotter) and remove one .10mm shim from your setup (you should be around .45mm of combustion chamber height).
If is from a .21 I don't see any reason to go lower nitro content unless you're facing runtime problems.
Corse-R is offline
Old 06-17-2007 | 09:52 AM
  #905
HarKonnenD's Avatar
Corse-R - Sry for not clarifying, but yes I was refering to a .12. Is the .45mm height recommended for any .12 or the Ninja in specific.
Old 06-17-2007 | 10:19 AM
  #906
Corse-R's Avatar
This was the setup of a Ninja I borrowed from a friend this weekend for a test. Testing was done at around 2000ft high with a 16% nitro.
From 16 to 20% isn't much difference so you can leave this height and test.
Corse-R is offline
Old 06-17-2007 | 04:57 PM
  #907
royfan33's Avatar
Anyone know the heat range of Ninja plugs? I'm assuming 5, 6, 7. Hottest to coldest. I feel I need a hotter plug and I got a couple of 5's, was running 6,but they didn't change my tune much at all, and eyeballing them the 5's look virtually identical to the 6's to me.
FWIW, I'm running right at 5000ft alt. w/30% nitro. To get it up on the pipe it seems like I'm having to run on the lean side.
royfan33 is offline
Old 06-18-2007 | 04:46 AM
  #908
Nitro$junkie's Avatar
Nitro$junkie is offline
Old 06-18-2007 | 10:05 AM
  #909
spenzalii's Avatar
Here's a question. I have the Ninja .12 and ran it with 30% Mugen fuel. I added that shim under the head before it saw a drop of fuel. I am bumping down to 25%. Should I remove the shim and go with a #6 plug? ( I was running that hot #5, and had a #7 at one point but dind't have time to tune it)
spenzalii is offline
Old 06-18-2007 | 12:39 PM
  #910
im going down from 30 to 20 (yes i know you should not do this)and iv taken out the shim,
in my nova motors i ran 25 with out putting in a shim and it was ok.
30%is just to hard to tune in the cores of the day,
and now going down in nitro % the motor will probably be slow but it will run
ill just have to get another motor.
Old 06-18-2007 | 02:11 PM
  #911
rmdhawaii's Avatar
Ron Hopkins from Werks Racing says that this thing about "lowering nitro % being a bad thing" is just a myth...
rmdhawaii is offline
Old 06-18-2007 | 04:44 PM
  #912
i hope so
and isn't ron hopkins a singer
Old 06-18-2007 | 05:53 PM
  #913
HarKonnenD's Avatar
I heard about that too. I also shown that 20% in a fast motor isn't going to make it any slower than using 30%. I ran against a Sirio Evo 3 STi on 20% and it was flying! I too will bump down and enjoy a longer lifespan on my motor.
Old 06-19-2007 | 12:46 AM
  #914
M7H's Avatar
M7H
Last year the runner-up in the Dutch Championship, drove 1 race with 16% nitro, instead of 25....
He won that race, and only noticed it was 16%, when he returned the can, and saw that he was missing a 16% can, instead of 25... (he has his own shop, and sells fuel)
Yes, you will notice it, but the difference is not that big.....
M7H is offline
Old 06-19-2007 | 01:57 PM
  #915
well this is good to know
i feel better now
was that guy a Dutch guy (like me)
and was he using tornado
