Ninja Engine by GRP
Old 12-27-2008 | 07:14 PM
  #1486
Any one have the part # for the GRP rod that fits the MR21 B01A?
Fred Perkins is offline
Old 03-12-2009 | 01:18 AM
  #1487
dtssystems's Avatar
Default Tuning MR12T10A
I'm having problems tuning this engine. Does anyone know the factory setting's?
dtssystems is offline
Old 03-12-2009 | 08:10 AM
  #1488
spenzalii's Avatar
I can check when I get home on mine and let you know. What is the engine doing or not doing?
spenzalii is offline
Old 03-14-2009 | 05:59 PM
  #1489
Taffyjnr5's Avatar
Hi,
I have just bought a second hand Ninja MR.12 T01A and was wondering what plug I should run with is as it came with a 5,6 and 7. I asked at my LHS an he said the 5 was too hot to run in it. Thanks
Taffyjnr5 is offline
Old 03-14-2009 | 08:50 PM
  #1490
spenzalii's Avatar
I've run 5's in mine since I got it with little problem. I know quite a few people run 7's though, which the motor seems to like once it's tuned.
Old 09-18-2009 | 10:39 AM
  #1491
Phatnandez's Avatar
Default Ninja MR .21 Glow Plug
Whats a good plug to run on the Ninja .21 Ninja? Am currently running an OS P3 Ultra Hot. is this a good plug to stick with? Thanks.
Phatnandez is offline
Old 09-18-2009 | 01:54 PM
  #1492
Robert Walker's Avatar
Did you ever find it? I would like the part# also.
Robert Walker is offline
Old 11-02-2009 | 01:07 PM
  #1493
r_weezee's Avatar
Default .12 Ninja Carb Settings
Can anybody tell me the factory carb settings for the MR12 T01? thanks
r_weezee is offline
Old 11-06-2009 | 10:59 PM
  #1494
gunna do's Avatar
Default ninja 12 jx
i believe that ninja is releaing the jx series on road engines is this true or not
gunna do is offline
Old 11-07-2009 | 01:14 AM
  #1495
jca2000au's Avatar
I heard that as well and look like it is going to be O.S. Speed base
jca2000au is offline
Old 11-12-2009 | 06:35 PM
  #1496
Ive been running a MR-B01A in an MBX5T this season and it has suffered from a lack of bottom end. I have used a 2050 and 9853 pipe on it. I switched to 1.1 spings and it helped a little. This past weekend i tried a JP-1 pipe and it really came alive. It definitly lowered the max rpm but im ok with that for now. I ran a 10 minute heat and still had some fuel in the tank without a pit stop. I have heard that the JP series pipes are fuel hogs. is there a better low end pipe i should be using?
thanks, Steve
stevef is offline
Old 11-23-2009 | 10:32 PM
  #1497
Xr Turbo's Avatar
Can anyone tell me where i can get parts for the GRP12 engines or am i out of luck
I would be grateful for any help
Xr Turbo is offline
Old 11-24-2009 | 03:25 AM
  #1498
jca2000au's Avatar
Mr. BM, what do you need?
Old 11-24-2009 | 01:53 PM
  #1499
Xr Turbo's Avatar
Hi Jay, I'm looking for a piston and liner for my MRT 12 but i don't like my chances.
I thought someone might know of a shop that has some old stock but no such luck
Looks like i'll have to run the Sirio EVO4 and the XXX and put the GRP on the shelf in the shed.
Xr Turbo is offline
Old 01-18-2010 | 01:17 AM
  #1500
zizgp's Avatar
Default Ninja MRT 21. sleeve and liner
guy,
where can i find piston sleeve for my Ninja MRT 21. engine. or anyone had old piston for this engine. My engine was good comprassion but the piston was had a problem. Please help me.. .
Thank ... you.
zizgp is offline
