Like Tree2Likes
ATOM engines thread
Old 02-19-2015 | 04:08 AM
  #61
sqamtech's Avatar
The photos of the internal will come soon !...
sqamtech is offline
Old 02-19-2015 | 07:06 PM
  #62
yeah i saw the internals on the web page.. looks nice... hope they come out with a hand modified version.. with dlc coating and epoxy filled..
DaRaceMasta is offline
Old 02-25-2015 | 12:45 PM
  #63
Send it to RW Mod For that!
tcb22185 is offline
Old 02-27-2015 | 11:34 PM
  #64
yes on point with that.. i know a guy here that does that type of work.. and well at that.. RW no doubt other wise.. if costs allow..
Old 02-28-2015 | 02:01 PM
  #65
ozziii's Avatar
Did it come with the HSN turned in that far, looks like it would be a bit lean.?
ozziii is offline
Old 02-28-2015 | 02:53 PM
  #66
sure it can be sorted by your own..
Old 05-20-2015 | 09:35 AM
  #67
Intech BR-6's Avatar
Dialed-RC Hobbies is now distributing the Atom Vortex Engines in the USA.
Now in stock.
Intech BR-6 is offline
Old 05-21-2015 | 02:02 AM
  #68
Now in stock.
i saw that in your email man... sweet azz let me know what you think of it in detail.. performance wise...
Old 06-14-2015 | 10:16 AM
  #69
mv91pony's Avatar
At mid break in now on this engine /pipe setup. Was a bit eratic at first probably due to the pinch but is starting to calm down and sit at a nice idle. Anybody run into a pingy lean sound during break in. Im sure this engine is not on the lean side at all. Not slobbery but atleast 2 hours outa race tune at this point. Runs well though and seems like a stout engine thus far.
mv91pony is offline
Old 06-15-2015 | 07:42 AM
  #70
ok.. hmm curious curiouser.... keep us updated.. 100 - 120c start up from new is ideal .. theres a connection between GO and these engines but its a OS V spec base.. so should be a sweet well priced engine none the less , in the past when running in a GO ie.. i had put the pre heating a touch up due to pinch 130 - 140 for starting and then maintain at 110 - 120...
Old 06-16-2015 | 06:19 PM
  #71
mv91pony's Avatar
absolutly, engine was heated to between 190 and 210f. Headed with gun then a head heater. Head covered during first 3 intervals . Used the houston break in method that has worked flawlessly for so far. Engine is ready to rip. Holds a great idle and seems to plenty for the truggy its in. Yes its is almost identical to a v.spec os.
mv91pony is offline
Old 06-16-2015 | 10:14 PM
  #72
NICE!
Old 07-26-2015 | 08:36 PM
  #73
Originally Posted by helena646
Mfg don't care about distribution anymore. They are a dime a dozen
MFG?? the guys that produce the engine?
shame they could have done well if they did care.. if thats the case..
Old 11-19-2015 | 05:14 AM
  #74
The Arrow GTR-II Plus 3+2 p/s can also be used in the Atom Vortex engines if you want a little more power for truggy.
Old 11-19-2015 | 07:32 AM
  #75
tysonsk's Avatar
Where can I buy this engine? How much does it cost?
tysonsk is offline
