Glow Plugs igniter Charging
#17
#18
i use one of these. i don't run electric so it's all i need. does every type of battery.
http://www.amainhobbies.com/product_...rger-6S-5A-50W
#19
Ok but what i am trying to ask is. Is it good or bad to charge the glow igniter from half charge, I know if you use a peak charger it will stop automatically but isn't it still bad?
#20
to give you an example. i will use mine one weekend, let it sit all week and then charge it up for the next weekend. then it will sit for 3 weeks and the do same thing next month. occasionally i'll discharge it.
#22
maybe with a nicad battery. but with nimh it's ok. just discharge it every so often.
#23
its not a high dollar old nimh race pack , youre good to go bro
#28
So would it be good to just give it a charge after use (I mean only when it starts to die but if i am going to the track the next day i'll give it a charge even if it is 3/4 charged) and then like every 3 months discharge it and then charge it up.
#29
yeah that's the go. don't charge it up until you're going to use it again. my ignitor has a 2700mah nimh battery in it and i can get a weekends racing out of it. but if your motors not tuned right and you have to use you ignitor more you may not get that runtime.
