Glow plug burning out on power panel
Hi Guys
I have a starter box with a power panel and never really used my ignitor plugged to the power panel to glow my plugs, until the other day, I running my starter off a lipo battery and even if I put the settings to low it will still blow my plug.
Is this normal when using lipo, I'm thinking the lipo may just give too many volts which is blowing it or do I just have a faulty panel, either way how can I fix this?
Thanks guys in advance
Hi Guys
This may sound obvious but It has happened to me on several occasions, make sure your ignitor is plugged into the "Glow" ports not the "12V" if you are smoken the glow plugs, you might be hitting them with 12V.
I did think it might be my lipo as its a 4cell, wonder if I can put a regulator or something and work around this!!
I run a OFNA adjustable cable start off 4S lipo all the time........ works like a charm....
I'm just trying to eliminate questions in my head but I am taking on board what you are saying.
I did try something in an unorthodox way to check how much voltage was coming out of the panel, I have a balance charger which can take external power in and requires between 11-18V DC to work so I used the the starter box panel plugged into the glow plug socket to send power to the balance charger and it came on!!
So now I'm thinking it is giving out too much voltage?!
