BuKu Performance Products CRANK CASE CAPS
#31
#32
#33
#34
#35
I guess she wasn't so clean after all LOL !!! Many people say to me they have never seen dirt in their front bearings...But I ask how often do people actually take the time to look for dirt ? Usually when someone's front bearing goes bad they blame the engine, or bearing brand, and never once consider the bearing getting gritty is just the collateral damage from a much larger issue... Of course the issue being that these engines are not sealed overly well and most of them breath thru the front bearings....The Buku dust cap will stop all of this...So for me the product is more then worth the cost...
#36
So I replaced the front bearing in one of my engines with a TKO. well, it leaks. I couldn't get a consistent idle so I sprayed brake cleaner behind the clutch and killed it instantly! I didn't even run a full tank of fuel through it and it leaks! I hate spending my money on junk! I bought 3. So, are these dust caps my solution or should I replace the bearing also? I planned on getting the dust caps anyway cause its a small price for the extra insurance of keeping dirt out. I've never had an engine suck dirt because I pay attention to my front bearings. I thought TKO bearings would be good. Guess not....
#37
Has anyone noticed longer run times after installing these shields? I would think so since technically you were running a rich tune to compensate for a front bearing air leak.
#38
#39
#42
#43
I have a MBX7 that will be here tomorrow, and I have never seen the back of a Mugen flywheel. Are they fine to use this???
Also is there a plan for a product that CAN be used with the Losi flywheel?!?
