Clutch Bell Shimming
Old 10-09-2014 | 12:43 AM
  #16
Nitro Tiger's Avatar
Get this kit, never have shimming problem again.
http://www.amain.com/OFNA-1-8-Clutch...Shim-Kit/p2940
The two black stepped washers with the desired std shims are a perfect remedy for the problem you have.
Also whats the gap behind the flywheel, should always keep it to a minimum, about 1-1.5mm
Nitro Tiger is offline
Old 10-09-2014 | 03:58 AM
  #17
Roelof's Avatar
Or use a countersink screw.
Roelof is offline
Old 10-09-2014 | 04:30 AM
  #18
alport78's Avatar
How much back and forth play should the clutchbell have ?
alport78 is offline
Old 10-09-2014 | 04:40 AM
  #19
HomicidalBunny's Avatar
I learnt that anywhere between .3mm and 1mm will do fine. TKO recommend between .3mm and .7mm for their Special Clutch bearings.
HomicidalBunny is offline
