HSN housing fell out, how to adjust?
Hi everyone, I've found the source of my lean syndrome in my losi XXL over half throttle. I noticed that the nipple on the HSN was extremely loose and the housing itself was, also. I took it out and I see that there are holes for the fuel to go through and realise that if these aren't aligned properly, I'll have issues.
How do I align them when I can't see them? I've been into nitro for a long time, but I've never had a drama like this, lol...
Cheers!
Cheers!
I am not familiar with that model / engine, but every motor I have seen has the ability to rotate the fuel nipple as you see fit.
It is a banjo fitting - designed to be screwed up tight in any orientation and it will work. That is why the "loop" part that slides on the HSN assembly has a big bowl kinda shape to it.
Post pics maybe?
Post pics maybe?
I don't think those holes have to line up.
I never worried about it. I always just set
Where I want the inlet nipple to be and tighten
Down the housing. Never had an issue.
If they don't have to line up, how does the fuel make it to the carb? I've tightened them down and I'm 90% sure they're close to lining up anyway, so I'll get some permatex copper tomorrow and reseal everything and hopefully cure the problems I've been having. It's extremely frustrating.
Hope this helps
This carb doesn't have washers. It's a Losi 454 not a nova, haha. I've been running nitro for years and I haven't had a drama with an engine like this. Anything over half throttle, it quits. There must be an airleak somewhere.
EDIT:
Here is a better picture. There definitely should be washer between the HSN housing, the fuel inlet, and the carb body.
What are the ACCURATE settings for the LOSI carb on the 454? The manual I have says 2.5 out on each needle, maybe it is way too lean, as some people are saying 3 turns or more?
I had it set to break in settings, 2.5 turns on the HSN and I added an extra 1/4 turn on the LSN for 2.75 turns out. It ran pretty hot like this, keen to get up to 300F according to the telemetry, but it never hesitated and died like it's doing now.
I have taken the needles back to where I started TONS of times and after half throttle it leans out way too much and dies.
I've just taken the engine apart and it all looks fine, there's nothing wrong with it. I sealed it up with permatex copper and also sealed the fuel tank primer up with this stuff (hope it's resistant to fuel!), I've followed some other word of mouth guides saying that 2.5 turns on the needles is too lean, and I've gone 3 out on each needle (even though I know 2.75 was plenty rich for the LSN, it' just a starting point to eliminate problems).
I don't know what else I can check for air leaks. I've changed the exhaust gasket, the fuel filter to an alloy one, the fuel line is new. If this doesn't work, I'll be stumped.
The 454 tends to want to be run on the richer side...once mine got above 250ish, it started acting ultra lean. Non-insulated carb.
