vspec vzb issue
vspec vzb issue
hi guys having a weired issue with a new v spec
i cant keep a constant tune?
it flames out but when i get the tune rite and i think its sweet it just sounds like it goes real rich then flames out its a newly run in beast in a newly built hb d8 running a jp4 pipe
i tried the usualy haunts tank, lines, carb leak etc swaped over the stock clutch, any ideas before i go and junk this motor for a new one ive always had dramas with v spec motors but never this early could it be anything else i tried a new pipe a hyper efra one thats realy old and the problem went away for half a tank then it came back i tried new plugs etc as well ?there is no leaks any were and the rod looks good as well
the only thing is the sleeve locating pin is missing in the block for some reason but the sleeve has been centred ?
black case un sure on weather its old or new style a os p3 plug
black case should be the old style with the long needles. would take needles back to flush and readjust the idle to .5-.7 and try re tuning
ok guys i got two whole tanks with out a flame out yay it seemed to be the two jp-4 jammin pipes i had purchased
OS T2060 or the efra 2041 pipe is the way to go with a vzb.
