BuKu Speed Tune Clutch & RC Performance Products
#1966
Hello, you have a couple PMs, thank you
#1969
How do you know when the shoes need replacing. What do i need to look for to know when this clutch needs replacing?
#1971
Cheers. I picked it up second hand so i'm not sure how many litres it has on it. I have put about 7 litres on it so i'm not to sure when i should replace it or replace the shoes. Is it hard to replace the shoes? Do you recommend to replace the shoes or do you put a whole new clutch in?
#1972
The posts are larger diameter than most clutches. They do not groove up easily and I reuse the flywheel once usually. I get around 8 maintenance free gallons before my zero shoe is paper thin. Then I throw all shoes away and start fresh
im running at many different tracks currently so it looks like I’m only going to get 4.5 maintenance free gallons this time. Im about to replace the shoes. It’s just as easy as looking at the friction material. Usually the 0 shoe will be the thinnest
#1973
What are your thoughts on buku caps? anyone using them? are they living up to the claims?
#1974
Hi!
Have any got trouble with the abk shoes? The komposite on one of my shoe as loosened and fall apart from the aluminium.
It hasnt even got 1 liter of driving!
Buku dont answer on email or on the website. Soon I will contact Paypal.
I am so dissapointed!
#1975
Buku clutch is a great product and i have used them for years! That has never happend to me. Some times things happends.
#1976
I have had the same thing happen in the past. When it happened to me I contacted BuKu and he sent me new shoes and everything was fine. Hopefully he will respond to your message. It does seem like he is having trouble keeping up with the demand on his product.
#1978
I have also had excellent results with BuKu Komposite clutch shoes. I overheated a clutch bell until it was glowing a dim red and the Komposite shoes still worked after the clutch bell cooled down.
Mass production makes products less expensive, it doesn't make them perfect. Sometimes defective parts sneak through quality control.
#1979
I had a composite shoes completely seperste jamming the clutch bell yesterday. Approximately 1/2 litre at the most use.
I will get in touch with Buku but I hope the quality isn`t dropping as I have had no issues before now.
#1980
I had one shoe pad fall off last fall. Happened within the first quart of fuel after installation, which seems to be the common thing. All others have been great for the life of the clutch. Never got replacement shoes and was put off several times but not by Dave. Clutch is amazing thankfully.
