BuKu Speed Tune Clutch & RC Performance Products
#151
#152
Guest
Correct size 32 or 34 for an RC8B and later
Gents,
A couple quick questions, In this thread it was stated that a 32mm clutch would be compatable for an RC8.B series but on the Absolute web site it lists the 34mm as being the correct part for a RC8...so which one is correct?
Also was going to order an OFNA vented bell but not sure if I need the standard or narrow bearing bell. I am assuming that standard and narrow are referring to the thickness of the bearing and affects the overall width dimension of the bell...Crap I dunno?
I just need to know which clutch and bell goes with an RC8.B series or later. I'm not able to actually go and look and there are no LHS in this part of the world. Just trying to buy everything for a new RC8.2 build so it's there when I get home...AKA retail therapy..LOL
Cheers
Cheers
#153
Gents,
Cheers
Cheers
34mm is stock. If you have a new wheel on your starter box the 32mm with give you a little more room for shimming and clearance between the flywheel and rear break disk. I have guys running the 34mm with no issues. Standard clutch bell
#155
Monty, I'm going to be trying them soon. I'll let ya know too buddy.
#158
Longer shoe life, bearing life,clutch bell life.The 3 shoes outside radius makes better contact with the ID of the clutch bell from new. That gives you better torque delivery and also a much more consistent clutch feel over the life of the shoes(and main).You typical 4 shoe wears from the tip to the rear of the shoe.So until there worn they are not making complete contact with the ID of the bell.By the time there (seated) in you have loss mass on the shoe (so they are lighter) now you need more rpm to engage the clutch, not to mention your bell is fouled with aluminum slag. This clutch addresses all those problems. Not to mention you now do clutch maintenance with a rag, not a dremal and exacto knife.
#160
If I was to grab a 1/8th Komposite clutch setup would you guys suggest grabbing a new clutch bell also? If so, what kind?
I'm currently using a Losi clutch setup on my Mugen truggy but my Alpha A352 should be delivered in the next day or two. I like the concept of this clutch though. It seems to be a lot more hassle free than the M2C adjustable setup where you add or remove weight.
Any feedback would be much appreciated?
I'm looking for something pretty aggressive.
#161
^^^ you MUST install a brand NEW clutch bell when using this clutch or else you will toast them in no time flat. I use the racers edge vented ones.
as for the D8 applications yes the 34mm is the one you want.
this clutch system is very nice and the adj. is awsome one of the smoothest clutches I have ran
#162
Okay, also in going to a higher power motor, is it safe to say I can go from a 13T up to a 14T clutch bell w/o losing too much acceleration?
I'm going from a Losi 427 to a Alpha A352 .23 truggy engine.
Lastly can the Buku be setup to be pretty aggressive?
#163
Let the gearing the same and tune the clutch to the track conditions.
#165
Then increase spring tension to what amount of aggresivness you want. Your options are from 1 oz to 150 oz
