Fms vs. rb fire
#31
Today I managed to squeeze in a tank in the back lane of the Fire 11 on a 2013.... This thing makes a ton of power on this pipe, yanks the heavy Badlands with authority ...it was even pulling little wheelies if I stabbed the throttle hard from a rolling start...I did notice a loss of top end with the 2013 compared to the 2058, but of course more low end punch... Considering this engine started as a top end rally engine I am very pleased with the results....
+ YouTube Video | |
#33
For international customers with the discount code from Tower, the Classico is the cheapest option here - $210 ($269 - $60 with code 014CD) before shipping...
As long as this stupid Greek referendum doesn't completely torpedo the Euro anytime soon...
BTW, re the Fire 11, if I were to get one, what about a pipe? Currently I could get the engine alone for €210, but the kit with 2045 costs just €20 more, so I'm assuming that's a no brainer?.. I have the following pipes: NR 9901/short or long, 2041, 2047, 2063(awesome with Piccos..), JP-4, 053, and the 0801 on the Argus.. The 2013 looks good in the vids, but def more for low-end - looks ideal for racing in truggies.. But for more top-end from the pipes I have, what do you reckon? I would assume 9901....
#34
Maximo, what plugs do you recommend for the RB F11? In Dubai, non of the hobby shop sells RB plugs except Nova's, OS, SH..
#35
#37
I mentioned this in the RB thread when you asked about the Classico as well. That engine will have a VERY small cooling head on it. That is made for onroad and the cooling head reflects that. Running with that head in a buggy or truggy your gona run too hot.
#38
#40
Some will say yes, I will say no ! the stock timing is very high and setup more towards onroad then offroad...My modified one runs much lower exhaust timing then stock, and much lower blowdown timing so it makes piles more torque then stock would.....
#41
So is a F11 the same as the old C6 or just similiar to? Are the timings different? I thought the C6 was known for decent low end and you say the stock F11 has questionable low end.
#42
edit... I should say that when I am talking about bottom end, I am not referring to blowing your tires off on a loose track, which I am positive a Fire 11 will do without any issue...The bottom end I am referring to is the kind that will push a truggy on a high bite track over a low speed technical section with authority, actual usuable torque when the tires are locked down... many .21's can feel very lazy down low when the traction is high....
#44
The clocked RB F11 certainly looks like a winner..
#45
What we know so far is that it is ridiculously powerful and fast..yet it is very forgiving and easy to tune... I swapped around 3 different pipes and 2 different plugs and the tune hardly wavered...it was not even really necessary to adjust the needles it was affected so little by the changes....And as I say it is extremely potent over the entire RPM range makes huge amounts of bottom end and right wails on the top end....Most positively definitely not a engine for the meek ! this one has some serious bite to it !
