Fms vs. rb fire
#17
#18
#19
stock Fire 11 internals
#20
How are the sleeves different? Is one much better than the other - i.e. is it a crapshoot if, when you buy one, you get the "right" one?...
#21
#22
There is definitely a place for the RB 11, just like the FMS had its place and it comes down to preference. Some like more bottom some like more top but but a preference i think we all share is an engine that is affordable, made of quality internals that will last and do so putting out a well rounded power band. RB has always put out long lasting quality engines and at the price these are going for i think they are a good choice.
I agree with Neal that in stock form out of the box these engines are timed for top end and IMO geared more twards buggy this way... not that they don't make a good truggy engine depending on your track layout etc. But in the right hands can be altered and make one heck of a truggy engine as well as buggy in all track layouts and situations and LAST doing it!
For those that really liked the FMS i think this is a great engine for you as they are VERY similar. Smooth usable power band = fast on the dirt!!
For bottom i suggest the 2013 for more top the 2058 works great as well. The videos Neal put up make this very clear and give a good idea of how the pipes change the characteristics of this engine. One key factor of any engine is choosing a pipe that best suits YOUR preference.
#23
style exhaust port cuts in the sleeve. Everywhere I have looked
the Rally engine is described as having a single exhaust port sleeve.
So yes, if you buy a real deal Fle-bay engine it is going to be a
crap shoot. If you buy one from Neal or a reputable dealer that
can assure you that the engine has the M.E.S. 3 sleeve. Then
you'll know what you're getting.
#24
The Fire 11 engines that Neal has received have the M.E.S. 3 port
It's more going to come down to new stock vs old stock. The newer ones will all have the MES. The older Rallys and the earlier versions of the Fire had a single exhaust port. The older F11 engines also have the really short old style L2G cooling heads. The newer F11's come with the heads like the B11. The newest Rally engine I have seen also had a MES.
#25
Here in Germany all these shops have popped up selling the Fire 11 cheaply.. - some shops I've never even heard of.. It's marked down everywhere..
I also have no idea what an MES exhaust is.., and I'm pretty sure most shops wouldn't either if I asked.. They all seem to be listing it as a 7+1...
#27
MES stands for Multi Exhaust System and will use 3 exhaust ports rather than one big exhaust port. When it comes to machine work it's going to be cheaper to make one big vs the 3 for the MES.
I don't think it's that they are suddenly selling them for super cheap at all. These engines have had a low dealer cost on them for several years. I have a few locals that have been running Rally engines in a truggy for a few seasons because they are soo cheap. Just not many people trusted a cheap RB would also be fast.
#28
Also note part of the reason these are cheaper is they come with the older style carb. it's not a bad carb in any way and tunes great, but the idle screw is on the front side of the carb when mounted in a offroad car so it will be up front by the flywheel rather than behind the carb. But heck 6 years ago all carbs were like this.....
#29
#30
it allows for a larger exhaust port without the risk of the piston falling out of the sleeve..its basically a single exhaust port with support bridging....
