Bullit rc engine
Old 04-20-2012 | 12:53 AM
  #121
Originally Posted by Rsickles
Look down into the carb with throttle open and see if the spray bar is a tapered or straight edge... along with what LSN needle it is.
Look at attached to familiarize yourself with differences.
Hi and thank you!
And if i donīt have the old oneīs ist it possible to change ONLY the needleīs?
Or must i change the complete carb?
Michael
iwillresist2008 is offline
Old 04-20-2012 | 01:25 AM
  #122
Rsickles's Avatar
You can change just the needles. You need three things + o-rings: LSN, slide valve, and mixture needle. Unfortunately you also need all three size carb o-rings (the mixture is small and large size, LSN is medium).
Rsickles is offline
Old 04-20-2012 | 06:30 AM
  #123
Coach Townsend's Avatar
So your saying the newer one is the better on 21J2
Coach Townsend is offline
Old 04-20-2012 | 03:51 PM
  #124
Officespace's Avatar
I got the new longer LSN & mid mixture needles from Gene at HobbyProUSA and they both came with o-rings already installed on them. It was just an easy switch out from the old needles to the new ones and then do a complete re-tune of the engine. There wasn't any need to mess with the slide valve.
Officespace is offline
Old 04-24-2012 | 06:04 PM
  #125
I dont understand why you guys are changing the needles. I have 3-4 gallons on my buggy engine with no problems and can get 10 at most tracks. 2 on my truggy and can get 12 min. Am I missing something? (I did not read the back post so was asking?)
PUDDIN is offline
Old 04-24-2012 | 06:29 PM
  #126
Originally Posted by Hobby Pro USA
Notice :
Running change on the Bullitt B-218 - it now comes with the old VZ-B long needle bottom end and mid range screws. This makes it eaier to tune, gives a smoother bottom end, and increases fuel mileage.
See the above post from Gene regarding the needle change.
I agree, the engine ran great and I got excellent run times before I swapped out the needles, but with the new needles, the engine is even better and is now a breeze to tune (which I didn't think was possible).
Old 05-20-2012 | 10:37 PM
  #127
Panic09's Avatar
Bump - any news for the bullit pipes?
Panic09 is offline
Old 05-22-2012 | 10:02 AM
  #128
Jon Hazlewood's Avatar
Hi,
Thanks for the interest. We hope to be able to offer the Bullitt pipe soon. We are working with OS on speeding up the process. Hope to have a firm answer soon.
Jon Hazlewood is offline
Old 06-29-2012 | 02:13 PM
  #129
Troy.Sears's Avatar
Yes, we will have a Bullitt 2060 pipe soon.
Any news on this?
Troy.Sears is offline
Old 08-06-2012 | 09:17 PM
  #130
Rsickles's Avatar
Who is making the B-2060 pipe?
It doesn't look OS based on the photos I've seen, so I am curious about the EFRA rating and if anything has been tweaked (meaning, possible better results).
Rsickles is offline
Old 08-07-2012 | 05:52 AM
  #131
The pipe is made in Italy, but it is basically the same pipe as the os 2060 only with the pressure nipple turned round.
Once os has finished with their current stock of pipes made in Japan the pipes from there on will all be made in Italy.
Scroggie is offline
Old 08-08-2012 | 04:00 AM
  #132
Glorykid's Avatar
Hi, as Scroggie has said the pipe is being manufactured in Italy it is exactly the same as the OS pipe which is also manufactured in the same factory to the same spec. The Efra number is the same for both pipes, the 2060 is the model number.
There are no tweaks or changes to the inside of the pipe.
Glorykid is offline
Old 08-08-2012 | 06:41 AM
  #133
VPProUSA's Avatar
The bullitt B-2060 pipe is now in stock at Hobby Pro USA.
VPProUSA is offline
Old 08-10-2012 | 01:09 AM
  #134
MassiveMods's Avatar
maybe give the engine a go before making an opinion.
it would be more accurate. not having a go at you but its not really fair to someone trying to enter the market.
if you wanted an engine thats totally different , new case , head , internals etc etc you would be paying a price thats not really competitive. then the engine may not sell.
if its made by OS , which by the look of the carb , should be decent.
question , if its being made in taiwan why does it have made in japan on the ad ?
MassiveMods is offline
Old 08-10-2012 | 01:44 AM
  #135
Rsickles's Avatar
Did you post in the wrong thread or are you late to the party?
Rsickles is offline
