-   Offroad Nitro Engine Forum (https://www.rctech.net/forum/offroad-nitro-engine-forum-157/)
-   -   FUSION X ENGINES THREAD (https://www.rctech.net/forum/offroad-nitro-engine-forum/490156-fusion-x-engines-thread.html)
houston 09-06-2012 12:09 PM
Originally Posted by RockStar_199 (Post 11180742)
I tried an x3 for practice today, I like it. It has about 4 gallons on it after it was rebuilt from an x3L and although the motor itself was very loud (not the exhaust) I am very impressed with it. I would really like to try a brand new one sometime
Loud?
He should check his bearings
X3 is a great engine fosho
RockStar_199 09-06-2012 07:35 PM
Originally Posted by houston (Post 11180787)
Loud?
as far as i know they are new, i bought it off of a member here and he said that it was a modded x3 and that it blew a rod and a stock PSR was put back in as well as new bearings. And if i remember correctly you did the work on it but i could be wrong.
I was going to check the bearings but i figure for what i paid for it it's a good practice motor ;) ill be looking into getting a new one soon :D
RockStar_199 09-06-2012 07:42 PM
just looked at the post again and you did some work on it but it dosent say anything about a new rear bearing,,do you happen to remember if theres a new bearing in it? if not no biggie think ill put a new one in and see
http://www.rctech.net/forum/r-c-item...-full-mod.html
Hobbs263 09-06-2012 08:51 PM
Hey Monty,
I have about 1 gallon through an x3l, and it has a lean bog that i can't seem to get rid of. I am running a 2096 pipe with a 7mm venturi.. the needles are very close to flush..the only way I can get the bog to go away is if i run the hsn pretty rich. The gas tank seems to be fine. The motor idles amazing I just cant seem to figure out the lean bog on the bottom end.
houston 09-06-2012 08:52 PM
Hmmmm , who'd it come from?
houston 09-06-2012 08:54 PM
Originally Posted by Hobbs263 (Post 11182622)
Hey Monty,
Try flushing out the hsn and reset to 4 turns from bottomed out
Make sure its NOT THE CLUTCH first ;)
RockStar_199 09-06-2012 09:47 PM
Link is in the post above
houston 09-07-2012 03:51 PM
soooo ,X3 RACE is turbo head button , sorry for any confusion , well worth the price fosho!!
FUSIONX AUS/NZ 09-08-2012 09:09 PM
Originally Posted by morfn321 (Post 11180661)
Brand... I have read you can use odonals?
O'Donnell 97T works very well i have found'
Dave'
FUSION X ENGINES AUSTRALIA
fung_kyle 09-09-2012 09:28 AM
I'm interested in the Fusion X3 Lightning Extreme, does it differ a lot from the X3 Lightning performance wise? Also does FusionX plan on bringing out a X5 Lightning?
houston 09-09-2012 01:08 PM
fusion X3 race is the most inexpensive in the lineup , i can make anything Kyle :D
and to answer your ? in regards to the x3lightning and x3lightning xtreme , not a huge performance gain but 100% of my guys that hve had filled and unfilled crank much prefer the filled
if properly broken in right with a fuel that has a good castor oil blend of at least 6% the ceramics will far outlast the steel but no bearing is safe from plug filament debris which is instant death to the bearing and pretty much all components inside the engine
fung_kyle 09-09-2012 07:19 PM
How does the x3 lightning/ lightning extreme compare to plus 4 or the p5?
houston 09-09-2012 10:08 PM
:D
fung_kyle 09-09-2012 10:11 PM
Okay... How about the X3LX vs Plus4c Team?
houston 09-09-2012 11:08 PM
All i am gonna say is if it is made by novarossi , you will be happy with it it ;)
All fusion x engines are 100% made by novarossi to our specifications :D
